OBD-II / DLC3 pinouts (headlight leveling system problem)
Old 12-18-11, 06:59 PM
Habious
Habious's Avatar
Default OBD-II / DLC3 pinouts (headlight leveling system problem)
Does anyone have the pinouts for the DLC3 connector on the SC430 (2003)?
It's the OBD-II connector, but the service manual refers to it as the DLC3 connector.
I replaced my headlight leveling sensor on the back axle this weekend.
However, instead of getting an intermittent headlight-failure lamp...I'm getting a constant one.
Found a link to a set of instructions that says after replacing the sensor, I need to short "XDA and CG terminals of the DLC3 connector and operating the light control switch."
Here's the link to the article. Granted, it's for a Prius, but it's still the Toyota headlight leveling system. And a search for SC430-specific stuff turned up ziltch.
Any help on this would be greatly appreciated.
Old 12-19-11, 08:15 AM
VVTiBob
VVTiBob's Avatar
I've searched through my printed and pdf versions of the manuals and cannot find a pinout connector chart for the DL3 connector... Looks like TIS may be your solution. But here's the more specific HL system info on our cars.
Regrets,
Bob
File Type: pdf
Old 12-19-11, 04:23 PM
JohnnyCake
JohnnyCake's Avatar
Great find on the reset article, Habious!
Apparently there is a "no scan-tool needed dance" for resetting the AFS controller -- you know, one of those "press the switch eight times then open/close door three times" like we have to do when programming keys.
If anyone knows a dance for resetting the headlight leveling sensor ECU, that would solve the problem in a jiffy.
Old 12-20-11, 05:17 AM
talwang
talwang's Avatar
Regrets,
Bob
I think the XDA/CG info is either in oem repair manual volume 1 (more likely) or oem wiring diagrams manual, but I don't have the printed manual set with me right now.
Hairbear63
06-03-18 05:46 AM
sjpbug
IS F (2008-2014)
03-28-15 08:58 PM
arpeyer
Lighting
06-19-11 12:41 AM
isaacly
10-29-06 10:58 PM
Quick Reply: OBD-II / DLC3 pinouts (headlight leveling system problem)
