Window Exterior Weather Strip Question
Old Jun 14, 2011 | 04:34 PM
rennwerkes's Avatar
rennwerkes
Default Window Exterior Weather Strip Question
Has anyone replaced the weather stripping at the bottom of the window glass?
My glass has very faint markings which I'm guessing is caused by the weather stripping and the fact that the rubber is old and stiff.
Wondering how easy/hard it is to change out.
Thanks
Old Jun 14, 2011 | 07:04 PM
scyul's Avatar
scyul
Thanks
I assume you’re talking about the door windows…. In this case, it’s very easy to remove.
You have to detach the top portion of the rubber door seal (top corner above the door latch) to expose 1 screw. Remove the screw and lift the weather strip off.
The weather strip felt like material can be cleaned with soapy water and a finger brush (or your wife’s tooth brush) to remove the contaminants (grit) and than reinstalled.
Old Jun 14, 2011 | 07:47 PM
rennwerkes's Avatar
rennwerkes
As much as I'd want to use my wife's toothbrush for this job I think mine are so worn out that I'd be better off just replacing them.
Thanks for the tip about the screw. It's knowledge like that that'll save a lot of headache in the long run.
Old Jun 18, 2011 | 12:46 PM
BucBaby's Avatar
BucBaby
Has anyone replaced them? Mine have little white dots on them. I hate to say it, but my car is out in the Florida sun all day when I'm at work.
Old Mar 16, 2012 | 11:33 AM
LexoticJ's Avatar
LexoticJ
anybody know the part number for this on sewell? im looking to replace both passenger front and driver front seals...
Old Mar 16, 2012 | 11:42 AM
bacardi's Avatar
bacardi
bob
this would be a question for you. he needs the year of car.
Old Mar 16, 2012 | 11:44 AM
VVTiBob's Avatar
VVTiBob
year of your sc?
Old Mar 16, 2012 | 11:48 AM
bacardi's Avatar
bacardi
thanks bob, i new you would know.
Old Mar 16, 2012 | 11:55 AM
VVTiBob's Avatar
VVTiBob
68171-24021 for RH
68172-24021 for LH
Officially called the "Front Door Belt Molding"
Fits several year models 02-10
Attached Thumbnails Window Exterior Weather Strip Question-fdoorpartsdiagram.png
File Type: pdf
Old Mar 16, 2012 | 12:20 PM
LexoticJ's Avatar
LexoticJ
its actually on my 2007 is250... trying to see if this is fairly easy and something i could do my self... any diy's would be very helpful...
LexoticJ's Avatar
LexoticJ
is this just held in by 1 screw?
Old Mar 16, 2012 | 01:02 PM
VVTiBob's Avatar
VVTiBob
Well you better check the part number for an IS, I was looking at the SC and I suspect the doors are not the same length... I have not replaced mine, but it has been cleaned by the dealer before. I suspect to seat it properly you'll need to the take the entire interior door panel off. For the SC that's several screws, clips, window controls and interior door handle. Don't know about the IS though.
Calicraig2
Sep 26, 2016 09:39 AM
no1gsxr
Maintenance
Dec 9, 2008 06:48 AM
TeamAM
Aug 2, 2007 05:09 PM
doriano
Maintenance
Jun 16, 2003 12:10 AM
