Replacing Struts?
Old Jan 7, 2011 | 10:30 AM
momssc's Avatar
momssc
Default Replacing Struts?
Anyone have the torque specs for the large lower bolt and the 3 bolts on top and the middle shock bolt? Thanks
Old Jan 7, 2011 | 11:55 AM
VVTiBob's Avatar
VVTiBob
According to my 02 FSM
Front Shock Absorbers:
The three top bolt: 41ft/lbs
the middle bolt where the speed senors mounts: 48in/lbs
the lower shock absorber bracket bolt 116ft/lbs.
Torque the lower bolt should be done after the suspension is loaded.
and while your at it,
Front Wheel lugs are 76ft/lbs
Rear Shocks
The three top bolt: 47ft/lbs
the two middle bolts: 13ft/lbs
the lower bolt where it ties into rear suspension member 81ft/lbs.
Rear wheel lugs are 76ft/lbs
Old Jan 7, 2011 | 03:25 PM
momssc's Avatar
momssc
"the middle bolt where the speed senors mounts: 48in/lbs
Can you explain this more? I am talking about the center bolt of the shock shaft itself. Is that the one you are talking about? And where are these sensors? I didn't see any?
And how are you going to load the bottom bolt? With the car on the ground? There isn't any room to get under without jacking the car up???
Old Jan 7, 2011 | 04:38 PM
VVTiBob's Avatar
VVTiBob
21 Ft/lbs on the center bolt at the top of each shock absorber front and rear. Looking for a diagram now to help. Found it...
Additionally the black diamond shape in the diagram indicates non-reusable parts. which happens to be the center bolt you were asking about.
To clarify the speed sensor bolt, what I referred to as the middle one, I boxed it in red to highlight it.
Old Jan 7, 2011 | 04:41 PM
VVTiBob's Avatar
VVTiBob
I assume you'll have the car up on jack(s) and wheel(s) off ...the bottom bolt should be torqued after the car is back on the ground, or "loaded", rather than when it's off the ground.
Old Jan 7, 2011 | 05:46 PM
momssc's Avatar
momssc
Ahh ok I get which middle bolt you are talking about now. Thanks for the info!!
Old Jan 12, 2011 | 02:57 PM
momssc's Avatar
momssc
Another question. Does the upper control arm need to be separated from the lower unit to remove/replace strut ?
Old Jan 12, 2011 | 03:11 PM
VVTiBob's Avatar
VVTiBob
Yes.
Remove the clip and nut.
Then disconnect the upper suspension arm from
the steering knuckle.
When putting it all back together you need to stabilize or load the suspension before final torquing... The FSM suggests:
STABILIZE SUSPENSION
(a) Lower the vehicle.
(b) Press down on the vehicle several times to stabilize the suspension.
Old Jan 12, 2011 | 03:49 PM
Poqman's Avatar
Poqman
you may want to look at the tool I used to separate the upper control arm and the steering knuckle in the photo's of this link
https://www.clublexus.com/forums/sc-...r-install.html
Old Jan 12, 2011 | 05:37 PM
momssc's Avatar
momssc
WOW thanks for the info....guess I will be buying a tool tomorrow......
Old Jan 12, 2011 | 06:35 PM
Poqman's Avatar
Poqman
I borrowed this tool from Advance Auto for free. Just leave a deposit.
Old Jan 12, 2011 | 06:38 PM
momssc's Avatar
momssc
Yeah but I like to buy my tools even though I won't use it often.
Old Jan 13, 2011 | 07:45 AM
VVTiBob's Avatar
VVTiBob
For those of you who are REALLY REALLY into this you can order SST, or special service tools from Toyota/Lexus from this site: http://lexus.spx.com/detail.aspx?id=57&g=21 and more specifically for this job, the ball joint puller here: http://lexus.spx.com/hwtordr.aspx
Old Jan 13, 2011 | 03:12 PM
momssc's Avatar
momssc
BOB
do you have the torque spec for that castle-nut with the pin? Thanks
Old Jan 13, 2011 | 03:17 PM
VVTiBob's Avatar
VVTiBob
64 ft/lbs FSM says a new nut and pin should be used.
