Timing Belt price
Hi out there,
I just had my timing belt replaced. I used an independent mechanic that I have been using for 18 years; they specialize in Toyotas.
Since my '02 only has 34k miles on it, I asked them to replace the water pump & serpentine belt only if necessary.
They only replaced the timing belt & added $20 worth of antifreeze. The belt itself cost $49.95.
The total price for the repair came to $294.95.
Jerry Baumchen
Jerry Baumchen
Impressive. Do you think that's the walk-in price for anybody or does that reflect the 18 year relationship? In any case it's an attractive situation. I don't think I'd find that in my neighborhood.
That's a very good price. I dropped off my SC at the Lexus dealer today for a new timing belt and water pump, and I'm paying $660- with a coupon (water pump is $240- w/no additional labor charge if I get both done at the same time).
My '02 has 38.5K miles..... but age alone has deteriorated the belt and warrants replacement. My water and power steering pumps are also being replaced, as they're both showing corrosion due to age. (Also having the tranny fluid replaced and fuel-injection system flushed.)
i finally had mine done. i think the risk of breaking is small. but if it does break, your engine is toast.
you can have it done at toyota. i used to live in vegas and the service department at lexus of las vegas is filled with crooks. very dishonest. i would avoid going there.
Hi Alterious,
If it had been the Toyota that I currently own or any of the Toyotas that I have previously owned, I would not have done it. Those are not interference engines.
However, the Lexus 430 engine is an interference engine and I just did not want to take the chance of the belt failing while the engine was running. The costs of that mistake are far more than the ~$300 for the new belt.
YMMV,
JerryBaumchen
YMMV,
JerryBaumchen
yeah i hear that but the manual states 90k miles obviously i barely drive my car since i only have 52k miles on it lol. i just replaced the oil, cabin filter, filter and battery but i will look at the timing belt while replacing the foams on my 6x9s this weekend
I agree. You could make a superficial examination of the rubber condition by removing one of the cam pulley covers, but you sure have to remove a lot of stuff to get to that point. I am fairly sure you couldn't see much of the belt teeth to know if there's significant wear without going deeper. But perhaps a little knowledge is better than zero.
