brake peddle sticking
My brake peddal sticks intermittantly. Lexus wanted to replace the master cylinder but wouldn't guarantee that this will solve the problem.
Also, my parking brake light comes on intermittantly when I step on the brakes. This does not have any correlation with the above sticking peddle.
I want to get this fixed but don't want to spend money needlessly.
Suggestions?
Suggestions?
This sounds like the best course of action is to take the car in for a scan to see what, if any, error codes are being stored. Then an action plan for repairs or replacements can be recommended.
Because the Master Cylinder has never been a problem area in this forum, I'd get a second opinion from a different Lexus dealer.
The most common brake fix in this forum is making sure your brake fluid is topped off. It tends to dissapate and cause strange behavior. Just a thought...
Just to clarify what you mean by "brake pedal sticking," are you saying that the pedal does not return fully? Do you release it manually with your foot? How much pedal travel are we talking about? Just the last inch or does it stay on the floor and not return at all?
While the mechanic says you are not losing fluid, have you actually checked to see whether the fluid is full? That would definitely explain the parking light and may explain pedal problems.
I assume you have checked the assembly and pivot points for obstructions and/or ease of movement.
I actually took the test when I lived in Michigan and became certified for brake repair. Of course, that was 30 years ago, so maybe things have changed a bit!
At least back then, the brake pedal had a return spring which could become weak, resulting in the pedal behavior you mention. I have no idea whether our cars have that, but I assume they do. You don't have a signature which indicates the year of your car, but this would be a simple and inexpensive solution.
If not, it probably is the master cylinder. The one thing about brakes is that there are just not that many components -- its a pretty simple system (taking anti-lock out of the equation). That's the only reason I passed the test.
Normally, I would check the brake fluid level first or consider some brake bleeding or new brake pads.
I think your Lexus dealer should have already checked those.
You definitely need to get a second opinion from other repair shop since the master cylinder is quite expensive to replace.
In fact, I bet if you down shift suddenly, causing the car do decelerate rapidly, you can make the parking brake light come on without even touching the brake.
If its full (which I doubt), then what Talwag said.
I'd look for a new dealer or have the dealer get the regional reps involved. Swapping parts at your expense without really knowing what's wrong is not consistent with Lexus' philosophy, but, then again, maybe it is.
Wald GS
GS - 1st Gen (1993-1997)
Jun 6, 2003 12:23 PM
