Navigation door motor????
Old May 22, 2019 | 06:11 AM
Matthias's Avatar
Matthias
thank you!
I used the heat-gun to loosen it a bit and it came off on both, it still needed some force. Now i just have to deal with the pesky little screws again during assembly.
Old Feb 3, 2025 | 12:39 PM
edki1945's Avatar
edki1945
Default Navigation door control motor
Originally Posted by VVTiBob
Well it could be the motor, or it may be the wiring harness, or might be something as simple as a ground gone bad or the panel switch.
There are several diagnostics that can be run. There are seven(7) full pages of diagnostic codes and continuity/voltage tests. So what I'm trying to tell you is if you've already have the NAV display out you've done most of the labor already, unless you're very handy with a V/O meter and can access the diagnostic codes, sounds like its time to take it to the dealer to find out exactly what's wrong. Once armed with the correct diagnosis you can proceed.
I will tell you, the usual result after a tilt failure is to replace the harness or switch assembly BUT without the diagnostic codes it's just a WILD guess.
how can I find a replacement door motor? I tested mine with direct power and it still doesn't run. If I knew the RPM of the motor I can figure out what aftermarket mine would work.
Jewel707
IS - 1st Gen (2001-2005)
Sep 2, 2020 10:28 AM
AlexisIs
Feb 20, 2018 12:42 PM
NOsburn
Jul 23, 2016 08:29 AM
steerpike
RX - 3rd Gen (2010-2015)
Jul 5, 2016 12:26 AM
ual320jet
Jun 22, 2009 08:47 PM
