LED DRL Mod
Old Apr 25, 2009 | 03:24 PM
talwang's Avatar
talwang
Default LED DRL Mod
I installed the 9005 DRL modules and 68SMT Led bulbs ordered from V-Leds.
According to V-leds, I am the first one to try their DRL kits on the SC430.
They work beautifully, so I finally can get rid of the yellowish drl.
Highbeam is still working, so I do not know why others said the highbeam would lose its function.
They also work exactly the same in my 09 GS350.
The output of these 68SMT LED bulbs is DEFINITELY NOT as good as that of your stock 9005 filament bulbs at night.
However, underperforming highbeam doesn't mean the function is lost. It only means it performs less well than required.
If you often use your highbeam as a source of light to see the road at night, then you should not do this mod.
For DRL purpose, these LEDs look brighter than stock DRL (9005 bulbs at 50% power) and I am still able to do a highbeam flash when needed.
The way I see it, I just converted my highbeam to a much brighter second parking light.
LED DRL on
Highbeam on
Old Apr 25, 2009 | 03:31 PM
junjdm's Avatar
junjdm
looking good!
Old Apr 25, 2009 | 03:32 PM
KiNg430's Avatar
KiNg430
looks nice Tal
Old Apr 25, 2009 | 04:31 PM
talwang's Avatar
talwang
Originally Posted by junjdm
looking good!
The moment I saw your DRL thread, I knew I would get them for sure.
Old Apr 25, 2009 | 04:33 PM
talwang's Avatar
talwang
Originally Posted by KiNg430
looks nice Tal
In case you want to do it as well, here is the link.
http://www.v-leds.com/Exterior-LED/D...70276-1-3.html
Old Apr 28, 2009 | 09:01 PM
scdroptop's Avatar
scdroptop
looks awesome...mine are in the mail from china or somewhere supposed to get asap i will post pics and update my thread as well.
were the bulbs hard to replace? I am also doing the fogs and the 68's
Old Apr 29, 2009 | 01:27 PM
MRTUND350's Avatar
MRTUND350
China? Who did you buy them from? Obviously wasn't V-LEDS.com
Old Apr 29, 2009 | 07:59 PM
talwang's Avatar
talwang
9005 highbeam bulbs are not that hard to replace.
You can simply turn the socket and pull it out without dropping the front bumper.
If you also plan to change 168 parking light and foglight, dropping the front bumper will make your life much easier.
Old Apr 30, 2009 | 08:13 PM
Hey Johnny's Avatar
Hey Johnny
looks great!!!!
Old Feb 23, 2010 | 08:32 PM
dair805's Avatar
dair805
Any pics at night?
Old Feb 24, 2010 | 06:06 AM
langsdale's Avatar
langsdale
i think that looks really sharp. good choice!
Old Feb 27, 2010 | 09:01 AM
rclab1's Avatar
rclab1
I heard replacing your DRL with LED's will make it "flicker"?????
is that true? is there a module to prevent LED's flickering on the DRL's.?
Old Feb 27, 2010 | 12:22 PM
scdroptop's Avatar
scdroptop
I have done both of my SC's with LED's and I have gotten a little flicker on both.
Oddly enough, you can only tell when they are shining against your garage wall or when you pull up to a store and see the reflection.
My wife/buddies that have seen me in their rearview in their cars tell me they see no flicker. When you take pictures of the car, you see no flicker.
Doesn't bother me...I'm used to it. Seems like it goes away the longer you drive the car/longer the life of the bulb IDK...sure beats the ugly yellow DRL's any day...and sure beats a HID kit and the installation of one IMO. 30 minutes to do this mod tops...$40-$60 depending on the bulbs. I bought the 68SMT LED 9005's as well. Bought the fogs too just need to install.
Old Mar 24, 2010 | 11:03 PM
dair805's Avatar
dair805
Default is350 LED DRL
Nice ride!! your car looks ver nice! I wanted to do the same thing on my is350 but the 68-smd I bought did not work well. They problem was that with the engine running (of course) the DRL light on right? well with the led lights already installed they would start to flash a little which I think they should not be doing this, correct? I love the color but I do not like the way they flash.. it seems that the battery is dying or something. With the 9005 (OEM) it does not do that but again I do not like the yellowish color of the bulb. What is your recommendation about this since you are a experienced man?
Old Mar 25, 2010 | 01:31 AM
xenonrider's Avatar
xenonrider
One solution is to use a relay harness: it'll get power directly from the battery and you can tap the signal wires to your fuse box (spliced into the driver side fuse box "inj"). I have had mine hooked up for over a year and it has worked like a charm.
