Squeaking when top is down???
Old Jul 17, 2008 | 02:13 AM
da-bizket's Avatar
da-bizket
Default Squeaking when top is down???
I always thought it was my sway bar but, the other day I put the top up and it went away. The top back down in the trunk and the squeaking noise came back. This only seems to happen when the weather starts to get cooler/damper.
I put some dry silicone on the rubber roof supports in the trunk and the noise went away. Only for a day...
Anyone else have this happen to them? Any suggestions?
Thanks,
Mark (da-bizket)
Old Jul 17, 2008 | 08:10 AM
intdiamond's Avatar
intdiamond
Mine squeaks with the top down, too. I believe it's from all the flexing the car does with the top down...which is normal. (I own an '02, since new, w/32.8K) It started making noise after a couple years of use. A strut tower brace will help somewhat.
Old Jul 20, 2008 | 11:13 PM
roadrage's Avatar
roadrage
I believe all cars squeak after a while. It's from all the flexing the car does when driving, going up and down drive ways, ect... My girlfriend has a new MBZ has about 10K Miles on it and the frame squeaks when going up a drive way at an angle. It's not loud but you can definitely hear it. My Ford on the other note sounds like a Rocking Chair when i go up or down a driveway at an angle.
It's normal...
If it didn't squeak then your car would be stiff as a board probably ride like one too!!!
Old Jul 21, 2008 | 12:38 AM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
Once thing I noticed is that the squeaking was reduced dramatically by installing a front strut tower brace. At least with the top up, no issues with the top down on my car.
Old Jul 21, 2008 | 05:02 AM
da-bizket's Avatar
da-bizket
I have had the front strut tower brace for a while now. It does help some with the flex but, this does not seem to be a flexing problem. The top is just squeaking going over small bumps (on a flat surface) when it's in the trunk.
If it was a normal condition I think more people would be responding. I will try replacing the rubber supports, since the silicone spray stopped the noise in the short term.
Thanks,
Mark (da-bizket)
Old Jul 21, 2008 | 05:47 AM
mrblister's Avatar
mrblister
what strut bar did you use ? Cost ? Was there any special instructions for it
Thanks Buddy
Michele01
Suspension and Brakes
Oct 18, 2017 02:04 PM
ThumperPup
May 29, 2015 07:56 AM
rcracer
Apr 21, 2014 09:42 AM
Hbhandal
Jul 28, 2013 05:23 PM
Jmai22
GS - 1st Gen (1993-1997)
Dec 12, 2002 11:16 PM
