SC430 wheel fitment
Old Oct 22, 2025 | 11:33 AM
  #511
trdmr2156's Avatar
trdmr2156
6th Gear
Hi, checking size fitment for a friend's '03 sc430. Would 19x8.5 +25 (front) and 19x9.5 +20 (rear) wheels fit properly, without sticking out past the fenders? If so, what would be a good size tire to go with on those? Car is stock height, with no current plans to lower. While I'm asking, would a 19x8.5 +15 work up front, or is that too much?
Going off the chart it looks like they'll work but I wanted to double-check. So, mainly wanting to be sure that they aren't gonna be popping out further than the fenders, since it'll be stock height and won't have that extra negative camber to negate any wheel protrusion.
I appreciate any help on this from the people that know. Thanks.
Old Oct 23, 2025 | 06:57 PM
  #512
RofH's Avatar
RofH
Not sure if you were going by this threads first post and the .pdf attached that shows fitment. Scroll down on .pdf to SC’s numbers
https://www.clublexus.com/forums/sc4...m_content=post
Old Oct 26, 2025 | 10:25 AM
  #513
trdmr2156's Avatar
trdmr2156
6th Gear
Yeah, I was going by that .pdf, as well as the chart made by 'talwang'. There were just a couple differences between the two and since the wheel sizes I'm asking about are on the edge of what will supposedly work I just wanted to try to get confirmation or not. Mainly because a lot of the cars I've seen have been lowered and thereby have that extra negative camber to help push the upper lip back into the fender, so, since this car will be at stock height I just wanted to double-check, because I obviously don't want there to be any of the wheel/tire sticking past the fenders at all.
Old Nov 6, 2025 | 02:51 PM
  #514
texsexlex's Avatar
texsexlex
You should be ok with that fitment, the factory wheels sit so far inside rubbing from the wheel/tire size wont be an issue. The problem you may run into is if the shocks are worn, you may experience some rubbing from the car bottoming out, because shocks need replacing... if this makes sense
Old Nov 12, 2025 | 10:43 AM
  #515
trdmr2156's Avatar
trdmr2156
6th Gear
Yeah, I got ya. The car just had all new shocks installed a few months ago so hopefully that shouldn't be an issue. What would you think on tire sizes? I see a lot of 245/35 (front) and 275/30 (rear,) but after using a couple different tire calculators it's showing that a 245/40 (front) and 275/35 (rear) would be much closer to the stock circumference, so now I'm second guessing that as well.
*Edit - Nevermind. I was mistakingly entering 245/45 as the original tire size, which was obviously throwing off the calculations. haha
Old Nov 15, 2025 | 03:34 PM
  #516
SC300Es's Avatar
SC300Es
To the people using different Lexus wheels from other models. Are you using the same lugnuts?
Old Nov 15, 2025 | 06:43 PM
  #517
RofH's Avatar
RofH
Yes, we used same lugnuts from our stock wheels and put them on new wheels as they were still in good shape.
But if you want/need new OEM ones here’s the Part Numbers:
Next sales are around Black Friday and Christmas time with FREE Shipping and NO Sales Tax for out of state customers.
ALLOY WHEEL LOCKS
Part Number: 0027600901
0027600901 - Lexus Alloy Wheel Locks | Bell Lexus North Scottsdale, Scottsdale AZ
0027600901 - Lexus Alloy Wheel Locks | Treasure Coast Lexus, Ft. Pierce FL
0027600901 - Lexus Alloy Wheel Locks | Prestige Lexus, Ramsey NJ
WHEEL LUG NUT
Part Number: 9094201058
9094201058 - Lexus Wheel Lug Nut. HUB (FOR AXLE); HUB(FOR SPARE | Bell Lexus North Scottsdale, Scottsdale AZ
9094201058 - Lexus Wheel Lug Nut. HUB (FOR AXLE); HUB(FOR SPARE | Treasure Coast Lexus, Ft. Pierce FL
9094201058 - Lexus Wheel Lug Nut. HUB (FOR AXLE); HUB(FOR SPARE | Prestige Lexus, Ramsey NJ
Old Nov 15, 2025 | 08:02 PM
  #518
SC300Es's Avatar
SC300Es
ALLOY WHEEL LOCKS
WHEEL LUG NUT
Thanks. I'm gonna swap wheels from my GS to the SC for a day to see how it rides. Don't want to buy new set of lugs unless I have to.
Old Jan 11, 2026 | 06:07 AM
  #519
Koy3UZ's Avatar
Koy3UZ
8th Gear
Default 19" and 18" wheel options
considering a staggered set up with OEM suspension. I will not modify OEM suspension.
Will any of these options fit SC430?
Wheels: 19x8.5 and 19x9.5 with both +35 offsets
Tires: 245/35R19 front and 275/30R19 rear
Wheels: 18x8.5 and 18x9.5 with +35 and +30 offset respectively
Tires: 245/40R18 front and 275/35R18 rear
Thank you
Old Jan 11, 2026 | 08:58 AM
  #520
RofH's Avatar
RofH
Thank you
Yes, ALL looks good to me.
There are posts throughout this thread that might have exact same numbers as you have.
I’m assuming bore size is 60.1mm — you don’t want to have to deal with hub rings but if you do, get quality metal ones as the plastic ones will end up vibrating at certain speeds.
Maybe you’ve already seen this .pdf on first post of this thread that’s also useful — scroll down to SC430 Wheels Fitment — it will have info on 19” wheels
https://www.clublexus.com/forums/att...ls-fitment.doc
Good luck with your wheel / tire fitment and be sure to post pics of how they look and the stance of your SC.
It will give more recent info on wheel fitment to owners just joining CL or wanting to update their OEM stock wheels / tires.
* EDIT: Forgot to ask if you plan to put spacers to make wheels/ tires more flush with body?
Old Jan 11, 2026 | 09:08 AM
  #521
Koy3UZ's Avatar
Koy3UZ
8th Gear
Thank you very much.
Old Jan 22, 2026 | 10:21 AM
  #522
Koy3UZ's Avatar
Koy3UZ
8th Gear
Default 1 more option, rear wheel
I searched, but was not satisfied with the answers, and these wheels are on the expensive side. Need someone with experience and knowledge. Thank you.
With OEM suspension, will this rear wheel and tire fit without rubbing?
19x10.5 offset 43
285/30R19
Thank you
Old Jan 22, 2026 | 12:33 PM
  #523
RofH's Avatar
RofH
19x10.5 offset 43
285/30R19
Thank you
I'm thinking the offset of 43 might be a little too aggressive and could possibly rub -- according to the attached .pdf from this thread below -- scroll down to the "SC" section in the .pdf
File Type: pdf
Old Jan 23, 2026 | 07:05 AM
  #524
HelloJon's Avatar
HelloJon
10th Gear
That .pdf is really helpful, thanks for digging it back up. I consulted it numerous times before making my final choice a few months ago.
I’ve posted this link before, but here it is again. It helps you see the impacts of changes and provides measurements you can use. Hopefully it will help you zero in on the best setup for you.
https://tiresize.com/wheel-offset-calculator/
Both resources helped me make my final choice. I went with 19x9.5 with 35 offset all around (so I can rotate). Tires 255/35/19.
I did end up adding 20mm spacers to rear so it looks aggressive but doesn’t rub.
Note: I also upgraded to coilovers, so ride height was dropped slightly. I kept them adjusted to the OOB ‘middle’ ride setting and so far have no reason to change.
Wishing you success and be sure to update us with your decision. (Pictures are always appreciated too.)
Cheers!
Old Jan 31, 2026 | 06:41 AM
  #525
Koy3UZ's Avatar
Koy3UZ
8th Gear
Default +25 to +30 rear
OEM suspension and clearances.
I ordered 285/30R19 for rear tires. Front is 245/35R19 (close to stock dimension). Off set on rear wheel is safe at +25 to +30 (use spacer to get to there).
I'm going with MRR FS01 silver flow formed wheels 19x8.5 +35 front and 19x10 +30 rear from audiocityusa.com. They do custom wheel offset.
I will update.
