springs for a 2005
Old Sep 23, 2005 | 05:16 PM
mightyd's Avatar
mightyd
Default springs for a 2005
As some know, the suspension was changed from 2004 to 2005 such that after market springs for a 2004 will not fit on a 2005. Has anyone actually put lowering springs on a 2005 . If so, who was the manufacturer.
I had a set of Teins ready to install only to find out when everything was removed that they would not fit on a 2005 eventhough they said they would fit 2002 and up. Frustrating...
Thanks for the help.
Old Sep 23, 2005 | 05:22 PM
GSXOTIC's Avatar
GSXOTIC
Your Tein should fit if they are for 2002. Even though the spring changed in 2005, I believe the over all configuration did not. I got a set of Tein CS for 04' and according to the installer, they fit perfect.
Old Sep 23, 2005 | 08:11 PM
mightyd's Avatar
mightyd
Nope, the springs changed in 2005. Tein admits they were unaware about a change. I also checked with Lexus and they also confirmed a different part number for the springs from 2004 and 2005.
Old Sep 23, 2005 | 09:20 PM
GSXOTIC's Avatar
GSXOTIC
please check this post:
https://www.clublexus.com/forums/sho...d.php?t=152352
Rominl has the same Tein and it works.... anyone else????
Like Henry stated, its the spring rating. The OVER ALL construction did not change. So the 02-04 Tein should works.....
Old Sep 23, 2005 | 11:51 PM
rominl's Avatar
rominl
exclusive matchup
yes, the spring rate changed, but the overall suspension configuration i don't see how it could be changed. that's just me.
all i can say for sure is that the bolt area etc... are the same, so that tein cs will fit all yrs
unless the part of the shock to hold the spring is changed, i don't see why the springs won't fit
Old Sep 25, 2005 | 07:23 PM
mightyd's Avatar
mightyd
I saw the stock shocks and springs out of the car and I saw the new springs from Tein and there is no way they will fit. The front springs change out fine but the rear springs are way too big. By big I mean the circumference of the spring. Tein confirmed that we had the right springs.
Go figure..
Old Sep 26, 2005 | 12:41 AM
rominl's Avatar
rominl
exclusive matchup
you mean the 05 rear springs are much "bigger circumference" than the previous ones?
if so, that's interesting. seems like they are really softening up the rear suspension quite a bit huh?
Old Sep 26, 2005 | 12:01 PM
GSXOTIC's Avatar
GSXOTIC
so where does this lead to?
Henry, you got your Tein CS earlier than me I supposed. Which year is your Tein CS? I think ours is the same. Is this post an concern on our Tein. Man, I need to start learning these Tein....
Old Sep 26, 2005 | 01:10 PM
rominl's Avatar
rominl
exclusive matchup
hahaa, no there is no issue with our tein cs. it's still ok trust me. my car is running and i have seen the setup, it's fine. mine was on a 02 sc430
the difference is probably the spring seat that's on the stock shocks. the one for the 05 is probably a lot bigger to hold the 05 springs. if you put the 02-04 springs on it will probably not fit well. so that's the problem
but in terms of the strut tower connections, and also the bottom control arm connections i am pretty sure they are all the same, otherwise the tein cs we have won't even fit on the car
henry
Old Sep 26, 2005 | 07:10 PM
mightyd's Avatar
mightyd
The circumfrance of the Tein shock is too much for the stock seat. The Tein shocks have a taper and you can actually take the "fat" end of the spring and slide it over the the stock seat.
Is there maybe a slim chance that they put the wrong springs in the box?? Tein is looking into it.
Now 'm trying to see if coilovers will work on te 05.
Old Sep 27, 2005 | 12:16 AM
rominl's Avatar
rominl
exclusive matchup
i am not sure about putting the wrong springs (i think you meant springs, not shocks?), i have never seen the springs before
but i can assure you that the tein cs coilovers WILL fit on the 05. i have 05 with it (from tein cs that was on 02 sc430) and gsxotic has 05 with it as well (tein cs for 04)
Old Sep 27, 2005 | 08:56 PM
mightyd's Avatar
mightyd
Thanks...I'm in the process of having Tein confirm the coilovers are ok.
Blkexcoupe
General Classifieds
Jul 18, 2018 08:49 PM
KennyLexus
Feb 17, 2016 10:41 AM
ISFGEORGE
IS F (2008-2014)
Apr 20, 2013 10:40 AM
lillex06
Suspension
Jun 17, 2009 06:15 PM
