Tire Pressure Light on Dash. Anyone figured out how to disable it?????
Has anyone figured out how to disable the light itself. I plan on changing to larger wheels. I have done a search and located the sensor alarm under the steering wheel column to diable the alarm itself. There must be a way to diable the light. I really don't want to stick a piece of black tape on the dash. Has anyone figure out how to turn the darn light out itself?????
exclusive matchup
search is your friend. we got a faq up right at the sticky
https://www.clublexus.com/forums/sc430-2nd-gen-2001-2010/33475-faq-on-the-sc430.html
post 24
post 24
That was the first place I looked. That is where I found out how to disable the Tire Pressure Sensor Alarm. My question though is how do I disable the light itself. I read about popping the dash with a flat head screw driver but am a little leary that I may cause damage without seeing a picture of the actual location that you place the screwdirver to pop the dash. Anyone have a picture showing how this is done? With this procedure you are still covering up the light itself with a piece of black tape. Surely their must be a wire to the dash light itself that can be cut or removed to actually disable the light itself???? Any further thoughts , how to's, images would be greatly appreciated...
