Heater control Valve issue
Old Jun 21, 2025 | 09:40 PM
Freshblood's Avatar
Freshblood
10th Gear
Default Heater control Valve issue
So my ac is blowing hot air on any low setting except max cold air where I get cold air. So I replace my heater control valve and now I only get cold air and no heat
Old Jun 22, 2025 | 06:20 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
did you replace it or someone else and which did you replace, passenger or driver side?
Old Jun 22, 2025 | 10:13 AM
Freshblood's Avatar
Freshblood
10th Gear
I replaced it,thought there was the only one on the left side on passenger side
Old Jun 22, 2025 | 11:45 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Okay, so yes, there a total of four. Two control heat, one on drivers left side and one on right passenger side, the one you changed. All four are located in the center section of the dash and three of the four are located where you changed the passenger heater servo.
I know TMI but now we have that out of the way, let’s troubleshoot.
Since you changed the servo, do you see it moving when you adjust the passenger heat from cold to hot and hot to cold?
if so, do you have enough coolant in the radiator and is the engine warmed up?
psichotic
Mar 16, 2023 07:00 AM
nzepeda
Aug 25, 2016 02:16 PM
empera
Oct 29, 2014 08:50 AM
Biddles
May 14, 2014 12:04 PM
