Nav door question.
Old Jan 21, 2024 | 06:18 AM
SGB4570's Avatar
SGB4570
Default Nav door question.
So on my 2004 the original radio has been replaced/upgraded and the nav door no longer functions. Is there a way to run power to that button to make it work again? I would love to build some sort of little "glovebox" behind it to store sunglasses. Ideas?
Old Jan 23, 2024 | 06:10 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
is the door motor still there?
is the Nav screen still there?
if everything is still there, just reconnect everything.
also, check the motor with a 9vdc battery to make sure it still works.
Old Jan 23, 2024 | 09:20 AM
SGB4570's Avatar
SGB4570
I am not sure what all is there, or if it works, I've never seen the door open, I've had the console off and seen the bird's nest of wires in there and am half afraid of tearing it apart and messing something up as it all works good right now except for that upper door.
Old Jan 24, 2024 | 04:58 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
You could open the nav door to see if the screen is back there.
just gently push it up
Old Jan 24, 2024 | 11:21 AM
SGB4570's Avatar
SGB4570
Thanks I'll have a look!
Old Jan 25, 2024 | 04:51 AM
SGB4570's Avatar
SGB4570
And, if I find the wires to the button, will a + and - hookup make it work?
Old Jan 25, 2024 | 06:36 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
And, if I fine the wires to the button, will a + and - hookup make it work?
I am not sure it is that simple.
did you open the door to check for a screen?
the two motors are located on top of the screen assembly.
I took mine apart on my 2002 because it didn’t work.
Old Jan 25, 2024 | 06:40 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Here is the wiring diagram.
it does not show the Nav screen motors.
Old Jan 25, 2024 | 10:07 AM
SGB4570's Avatar
SGB4570
So the motors are part of the screen assembly? Won't work if the screen is not there?
And to me that's some scary stuff pulling that dash apart. And its been cold here so I haven't had a look yet.
Old Jan 25, 2024 | 10:20 AM
doobs's Avatar
doobs
Disassembling the nav unit is not for the faint of heart.
Lots of pieces, lots of screws, lots of opportunity for mayhem.
If you do it, take your time, take lots of pictures, and lay everything out in a line as you take it apart.
Good luck
Old Jan 25, 2024 | 02:11 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
And to me that's some scary stuff pulling that dash apart. And it’s been cold here so I haven't had a look yet.
the Nav screen and doors are one assembly but the screen can be removed and replaced. There are several members who replaced the screen with a computer and I think a couple put some kind of radio up there.
Old Jan 29, 2024 | 03:03 PM
SGB4570's Avatar
SGB4570
So to Bgw70,
Warmed up a bit here this weekend so we took the car for a ride, I did push the door open and yes, the screen is still in there.
The buttons for the Nav door are all above the "climate control" unit (not sure what its really called) along with some other stuff, its like the power to that row of buttons has been removed/unhooked, must be some way to re-hook them up yes????
Old Jan 30, 2024 | 03:47 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
So to Bgw70,
Please remove the climate control and look to see if the see connectors are attached properly.
also look to make sure the wires on the three connectors haven’t been cut.
See pics below,
there are four compression clips holding the climate control in place, just grab it like i did on each side with both hands and gently give it a tug/pull. The face may come loose, if it does, push it back on and readjust your hands. It really is simple.
in the second pic, note the three plugs.
sorry i don’t have a pic of the clips but you could easily find one on eBay to use as a reference.
Old Jan 31, 2024 | 04:45 AM
SGB4570's Avatar
SGB4570
See pics below,
Very cool, thanks.
It'll be a bit, got some surgery so maybe next week maybe. Unless I get brave this afternoon... I see your bottom door is open, best to do it that way?
I was thinking I would have to take out the console, then the radio in order to get to that climate control unit. This bit of knowledge make the job much easier! Again, thank you very much!
Old Jan 31, 2024 | 02:34 PM
SGB4570's Avatar
SGB4570
See pics below,
Ok, before I tear into this, This car has an after market head unit (Pioneer), when I pull the climate control unit and one or more plugs are unplugged, might it cause trouble with something else there if I plug it/them back in? Just don't want to screw something up.
