Steering colums wheel squeeks while turning
Old Oct 18, 2023 | 02:18 PM
JWC1966's Avatar
JWC1966
10th Gear
Default Steering colums wheel squeeks while turning
My 2006 SC430 has developed a squeak while I'm rotating the steering wheel. It occurs while stationary or moving. Tried spraying silicone behind the steering wheel. Any other suggestions?
Old Oct 18, 2023 | 04:01 PM
iolmaster's Avatar
iolmaster
Could be the clock spring.
Old Oct 18, 2023 | 09:30 PM
GmanSC's Avatar
GmanSC
Check the power steering fluid.
Old Oct 19, 2023 | 04:06 AM
JWC1966's Avatar
JWC1966
10th Gear
What's a clock spring, and how is it accessed?
Old Oct 19, 2023 | 06:30 AM
iolmaster's Avatar
iolmaster
It is an assembly inside the steering column that carries the electrical signals from the steering wheel to the systems in the car such as the radio. They do wear out but I do not know if they make noise when they do. It rotates around the column as you turn the wheel. Noise is certainly possible. You access it by taking off the steering wheel. Not as bad a job as you might imagine.
Old Oct 19, 2023 | 07:31 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
take a look at this thread and video
https://www.clublexus.com/forums/sc4...l#post11414140
Old Dec 8, 2023 | 09:20 AM
jimisbell's Avatar
jimisbell
Originally Posted by irontmp
No vibration, no humming, just squeaky noise from inside when turning the steering wheel. I started hearing this noise yesterday. Is this normal to hear something like this on a new car? Mine is about 3 weeks old. I can hear the noise when parked and driving as I turn my steering wheel. It almost sound like steering wheel is wrapped with tight foam and you are trying to turn it.
This car hasnt been made in 14 years. Yours cannot be NEW!
Old Dec 8, 2023 | 02:53 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
good call Jim, he must not be driving an SC430
RiceBanana
RX - 4th Gen (2016-2022)
Nov 20, 2021 01:56 PM
fastegg
Nov 8, 2021 09:05 PM
GISguy
Sep 14, 2016 02:43 PM
