TX Major NA-T Partout
Major NA-T Partout
-What is your First & Last name?: Jairo Herrera
-What is your email?: drft_n_sc@yahoo.com
-What is your phone number? : 817-673-1518
-What is your City? : Fort Worth
-What is your State? : TX
-What is your Zipcode? : 76114
Ok so the decision has been made and I am redoing my entire setup and getting rid of everything on the car. The car is a SC300 with an NA-T setup, I am runing a GTE ECU and deleted the distributor.
I have decided to go with a totally different setup and I've already started pulling everything out. Here is what I have availabe so far ...
Modified Godspeed front mount Intercooler - $300
Custom IC Piping - $550
Custom 2jz-ge FFIM - $600
Nissan Q45 and 90mm throttle body with TPS – $120
HKS adjustable cam gears – $200
BOV Greedy Type RS - $300
48mm wastegate - $60
T4 turbo Manifold - $250
Garrett T4 Turbo (rebuilt 11/23/2011 with new t4 hybrid) - $780
Modified Downpipe - $150
Supra GTE Coil packs - $120
Supra GTE Igniter - $OLD
Supra MAF - $80
Supra GTE 5spd OBD1 ECU – $200
2JZ-GE Wiring Harness - $OLD
SAFC neo - $300
Supra 7M CPS - $OLD
Supra 7M 440cc injectors with resistor pack - $250
W58 5 spd tranny with stage 4 clutch and 10 lbs flywheel; less than 70 miles on both - $920 (clutch and flywheel alone were $700)
Stock Supra side mount intercooler – $100
2jz ge 5spd ecu – $180
Tapped union bolt for oil feed line – $OLD
-3 ss Oil feed line – $30
-10 ss Oil return line – $50
Greddy boost gauge – $130
GFB manual boost controller – $40
Vacuum block – $50
2jzge a/c compressor - $200
Sc300/400 climate control unit - $100
Sc300 5speed instrument cluster – $200
Pair of stock Sc300/400 front upper control arms - $130
Pics upon request and don't be afraid to ask any questions, I will be more than happy to fill you in on anything you wish to know about what I'm selling.
Buy with confidence, I will also be posting this stuff on SupraForums, so first come first served, I will be as honest and as as fair as I can possibly be with everyone and anyone.
Thanks for looking
Supra MAF - $80
SAFC neo - $300
Supra 7M CPS - $OLD
Vacuum block – $50
Thanks for looking
Update on whats been sold and answering your questions
BAD954BOI: here are the pics of the FFIM
DZLEXIK: I can do the control arms and the flywheel for $425 shipped
2slowsc300: The IC piping has already been routed for a FFIM, I know you can buy a kit brand new for $400 but you're still going to spend more money on routing the piping correctly.
DeezNuts: I am selling them as a pair
djkevin510
SC- 1st Gen (1992-2000)
17
01-06-10 06:46 PM
