GA Boostlogic Stage 2 kit
Old Jul 14, 2009 | 06:24 AM
craaaazzy's Avatar
craaaazzy
Default Boostlogic Stage 2 kit
*******SOLD SOLD SOLD *****
hey guys,
i'm finally putting up my Boostlogic Stage 2 kit for sale. all parts were installed by myself and a few good friends (one being clark w/ black supra if u guys are local - Projectmk4>R1 on supraforums). kit has 3k miles at the most.
this is a cut/paste from boostlogic site (i've noted parts NOT included or UPGRADED):
List of parts included:
* Boost Logic Ceramic Heat Coated 321SS Tubular Manifold 1 5/8” Tubing and 1/2” Thick 321SS Flanges (Turbo’s with a 4” inlet clears the distributor. Manifold fits a turbo up to a T76)
* T61 .58A/R Ptrim Turbo w/ T4 flange
* HKS 40mm Wastegate (I'VE GOT THE 19LBS SPRING INSTALLED BUT WILL INCLUDE I BELIEVE A 10LBS SPRING AS WELL)
* 3” SS304 Polished Downpipe w/ Flex Joint (DOWNPIPE IS HEATWRAPPED)
* 3” SS304 Polished Midpipe (THIS WAS MODIFIED AND WELDED TO FIT STOCK EXHAUST AND INCLUDES ELECTRIC CUTOUT FROM QTP - must take full exhaust system, else u need to buy a midpipe).
* SS304 Polished Dump Tube
* 3” Polished Aluminum Intake Pipe (INTAKE PIPE IS HEATWRAPPED)
* Boost Logic 750HP Front Mount Intercooler Kit (THIS INTERCOOLER KIT NOT INCLUDED AS I BUILD MY OWN USING 3" XSPOWER INTERCOOLER)
o 2.5" Mandrel Bent Aluminum Intercooler Piping (NOT THIS PIPING - USED DAVEH PIPING)
o 4 Ply Silicone Couplings
o Stainless Steel Hose Clamps
* Boost Logic NA-T SS Braided Oil Feed and Return Kit w/ Aeroquip fittings
* 3” K&N Filter
* K&N Breathers
* Walbro GSS341 255HP Fuel Pump w/ Install Kit (FUEL PUMP NOT INCLUDED SO U WILL NEED TO BUY A WALBRO OR DENSO BUT I HAVE A FILTER and -6 line)
* All necessary clamps and bolts for installation
Stage II Upgrades
* Boost Logic 2.5mm Head Gasket (INSTALLED ON ENGINE WHICH WILL GO W/ KIT IF U BUY THE WHOLE THING)
* 440CC Injectors x 6 (fits in the stock rail) (KIT WILL COME W/ PRECISION 880'S AND MKIII INJECTOR BOX)
* Injector Piggy Tails x 6
* ARP Head Studs (INSTALLED ON ENGINE)
i am also including in this kit:
stock wiring harness
another thing that was installed was a new lower oil pan. also, the upper oil pan was drilled for oil return. stock exhaust which was modified to fit the boostlogic midpipe is also included and has electric cut out (this was an awesome upgrade...keep it quiet or make it loud when you want).
this is pretty much a direct swap for anyone. pretty much everything other than the fuel pump.
I'M LOOKING TO SELL EVERYTHING AS A WHOLE AT $SOLD. this is $1.3k less than what boostlogic is selling their new kit for...but you get upgraded injectors w/ injector box, engine w/ ARP headstuds, headgasket, oil drain already installed, and QTP Y-pipe.
i would also recommend getting the following (but not required if running low boost):
*HKS Twin Power Ign Amp - $300 SOLD
*Shift/lean lights - $30
*SMC Meth kit - $300
*Turbo blanket - SOLD
*AEM Uego controller wideband - $150
please let me know if u have any questions. pictures will be posted in the next post down.
i've had a good standing on this forum as well as supraforums (same name as here), clubna-t, and bimmerforums. i've sold parts to fellow members on all forums also. simply search my name and see what u come up with if ur worried.
thanks guys,
fred
Old Jul 14, 2009 | 06:30 AM
craaaazzy's Avatar
craaaazzy
some pics i have:
Old Jul 14, 2009 | 07:24 AM
chitwnsazn's Avatar
chitwnsazn
Can you clarify, are you selling the entire engine as well?
Old Jul 14, 2009 | 07:27 AM
craaaazzy's Avatar
craaaazzy
the engine will go to whoever buys the kit. not selling it separately at this time.
Old Jul 14, 2009 | 08:32 AM
lenny's Avatar
lenny
seems like a good deal!
Old Jul 15, 2009 | 06:49 AM
craaaazzy's Avatar
craaaazzy
thanks, hopefully someone will want this. else, i'll need to look for a car to install this in myself.
Old Jul 28, 2009 | 10:49 AM
craaaazzy's Avatar
craaaazzy
somebody wants to make over 500rwhp...
Old Jul 30, 2009 | 09:14 PM
craaaazzy's Avatar
craaaazzy
aem is sold as well as the 3bar sensor.
updated price accordingly.
btw, not sure if i wasn't clear but the recommended parts are also for sale (such as he HKS Twin Power Ign. Amp, shift lights, SMC Meth kit, and turbo blanket)
Old Aug 10, 2009 | 11:46 AM
craaaazzy's Avatar
craaaazzy
up up and away
Old Aug 10, 2009 | 03:43 PM
chitwnsazn's Avatar
chitwnsazn
How many miles on the engine and its condition (i.e. does it need new valve stem seals, any leaks, etc.)?
What is the condition of the turbo?
Thanks
Old Aug 10, 2009 | 05:00 PM
craaaazzy's Avatar
craaaazzy
engine had about 213k miles on it when pulled. i never did seals or anything. when i bought the car, it had 209k and the previous owner had done the timing chain not too long ago. never smoked, no oil leaks, etc.
as for the turbo, it is as new as it can be w/ 3k miles on it. no shaft play. oil changed every 2k miles w/ mobil1 synth.
i've owned the car over 2.5 year so u can see how many miles i drove it. i regret not enjoying the car more...
Old Aug 10, 2009 | 09:56 PM
turbodremz's Avatar
turbodremz
I'm interested in a few parts from the kit, if your willing to separate send me a pm.
Old Aug 17, 2009 | 07:58 AM
craaaazzy's Avatar
craaaazzy
up again...
Old Aug 21, 2009 | 06:10 AM
craaaazzy's Avatar
craaaazzy
price dropped to $3949...
Old Sep 16, 2009 | 08:57 AM
craaaazzy's Avatar
craaaazzy
up again...
