I need a front passenger's side hub assembly (complete assembly, including wheel bearing)...I think the entire assembly is swappable driver's side to passenger's side but I'm not positive. I know it IS swappable in the rear, not sure about front. Either way, I need an assembly ASAP and therefore preferrably in or near NY? I need to have the part in my hands by sometime Thursday so I can have the car repaired on Friday.
I'll sell you the whole spindle with hub for $80. I think you should use this hub back with your spindle. I'm located in Brooklyn NY. If your interested i'll PM you my contact info.
if you give me the entire thing, I can just swap your unit fully with mine right? Unless your spindle is somehow damaged? My wheel bearing has gone bad and so I need that replaced, but I'm fairly certain that the wheel bearing has damaged my hub as well so I need the entire assembly. By spindle do you mean the part with the bolts for the lugnuts on it? If so, I need that as well since my spindle only has 4 lugs. I don't understand exactly what you are saying...but if you are in BK I can maybe pick it up sometime this week...how many miles on it?
