Need replacement sub for 02 Plug & Play
Old Sep 12, 2011 | 09:11 PM
wbrewster's Avatar
wbrewster
Default Need replacement sub for 02 Plug & Play
I had my LuxLink installed today (flawless install by BestBuy and I love it) and turns out my sub is bad. Does anyone know of a sub that I can pop in with minimal mods? Sorry if their is a posting already on this but I could not find one. Thanks, Wayne
Old Sep 12, 2011 | 09:58 PM
irokdastar's Avatar
irokdastar
you can buy any sub the same size and there is a 2 wire connection. it will not have oem connections so you will have to splice and wire them in . its simple. just strip the oem wire ( try doinging this as far back away from the connector as possible) the red is positive and black is negative and your done. or just go back to bestbuy and have them install it.
Old Sep 12, 2011 | 10:48 PM
i2fat's Avatar
i2fat
I have a sub for sale. The original ML that came in my SC430, if you're interested let me know.
Included a link to the thread... Mark Levinson Subwoofer For Sale
Old Sep 13, 2011 | 05:01 AM
redliner8's Avatar
redliner8
How much did Best Buy charge? If you don't mind sharing. I could do the install myself but hate soldering lol
Old Sep 13, 2011 | 07:17 PM
jzwu's Avatar
jzwu
You need to match the new sub with the oem sub on resistance and size.
Old Sep 13, 2011 | 11:52 PM
wbrewster's Avatar
wbrewster
Best Buy charged $450 but underestimated it. It took 8 hours. They get $85/hr. I used the Emeryville, CA store. They do outstanding work. I have used them many times.
Old Sep 14, 2011 | 07:48 AM
robertrios's Avatar
robertrios
my installer took 9.5hrs i got 4 for free so i paid 5.5 @ 70hr at audio itch, everything works great except rear window module which im going to take out the back seats and check out per Steve they might just have not cut the black wire loop for 2 window use.
Old Sep 14, 2011 | 07:50 AM
robertrios's Avatar
robertrios
also forgot to mention, NO you cannot just drop any sub in from the same size, all speakers have different OHM loads so unless you want to destroy your ML amp I would recommend buying that OEM sub, disconnecting your sub and adding an aftermarket sub and amp using those leads via a high to low module, or finding a sub with the exact same OHMs are our OEM ML sub.
vboi4life
Oct 27, 2012 05:41 PM
Frankdorn
May 28, 2010 10:26 AM
KKRlexus
Nov 20, 2008 08:36 AM
biglexgs
Sep 9, 2005 03:09 PM
vicestan
May 24, 2005 10:06 AM
