HELP!!! My wipers are stuck on!?!?!
Old Oct 13, 2009 | 08:22 PM
1JZ/240sx's Avatar
1JZ/240sx
Unhappy HELP!!! My wipers are stuck on!?!?!
The wipers are not turning off...
they will go to the fast speed, but will not go to intermident or off
I havent driven the car in 3 weeks,
and for some reason thee wipers have gon on the fritz
Has anyone had a similar experience?
Or maybe have some ideas as to what could have caused it?
thanks for any starting pointers
here is relentless window wiping wonder wagon
Last edited by 1JZ/240sx; Oct 13, 2009 at 08:57 PM. Reason: for the CL search engine
Old Oct 13, 2009 | 09:00 PM
IOWNALEXUS's Avatar
IOWNALEXUS
They are trying to wipe off the BMW roundel's............
Old Oct 14, 2009 | 08:51 AM
Luxor's Avatar
Luxor
Your car is too low and your tires have made contact with the wire harness under your front fender. You might want to take off your front wheels and take a look under there to see any exposed wires.
Old Oct 14, 2009 | 11:52 AM
Dirty SC's Avatar
Dirty SC
holy **** how did u get those wheels to fit your SC? do u have any more pics?
and about the wiper motors. definatly check under your tires most likley the driver side. wires might be eaten up by it rubbing on the tire.
Old Oct 14, 2009 | 02:06 PM
LSEGHATCH's Avatar
LSEGHATCH
Either the wires are exposed or moisture is getting into the relay/wires. Usually happens when it is wet/damp?
Old Oct 14, 2009 | 09:13 PM
1JZ/240sx's Avatar
1JZ/240sx
i got tommor off so i guess ill figure it out
Originally Posted by Luxor
Your car is too low
lol...seriously
relocate your harness
never worry again
Old Oct 14, 2009 | 10:06 PM
HeisLegend's Avatar
HeisLegend
mine don't work.
I relocated after the fact. hahaha.
But yes, there should be some wires seperate of the main harness collection of wires.
let us know how it goes, bruh.
Old Oct 14, 2009 | 10:30 PM
RedPhoenix's Avatar
RedPhoenix
You killed the harness under your driver fender.
Old Oct 15, 2009 | 05:23 AM
Dirty SC's Avatar
Dirty SC
please post more pics of that SC with the M6 wheels
Old Jan 22, 2013 | 05:13 PM
bippu250's Avatar
bippu250
having the same problem only my wiring harness has already been relocated. any ideas on whats going on?
Old Jan 22, 2013 | 06:05 PM
ASTERiSK's Avatar
ASTERiSK
That's weird, I have the same problem but it happened after I relocated the harnesses. Maybe I need to take a look at them again.
Old Jan 22, 2013 | 06:23 PM
Kalogerus's Avatar
Kalogerus
I read about this issue twice before. Everything points to the harness.
Side note: That is a SICK looking SC.
Old Jan 22, 2013 | 07:00 PM
TheAzn's Avatar
TheAzn
Temporary fix would be to pull the fuse that controls the wipers.
mlacomb
14
Dec 1, 2014 08:38 AM
CJS57
21
Feb 3, 2010 12:24 PM
Superjatt
Oct 27, 2009 09:23 PM
TEXAS83
Jul 4, 2006 10:31 AM
IS-250
Jun 2, 2006 11:32 AM
