Riding Redline for awhile...Engine starts stalling...?
Old Oct 10, 2003 | 04:06 PM
One HoT's Avatar
One HoT
CL Folding 10,000
Default Riding Redline for awhile...Engine starts stalling...?
On my way to my usual college frat party last night, I was going around 60MPH on the Northern State when I saw a brand new silver Porshe Carrera S...He pulls up next to me and punches it, so I thought to myself...Hey, why not? I can't back out on some fun on the highway...Knowing pretty well that he'll smoke me like I was standing still, I punched it anyway...Since he had a head start and had a 7 car lead, I was playing catch up...I turned my OD off and my Power mode on...I was riding redline going 120MPH, then my engine started to stall going at 130MPH and lost a lot of power...
I let off on the gas and then the car was running normal again...
Is it normal for the engine to lose that much power and stall riding redline?
Old Oct 10, 2003 | 04:11 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Fuel pump cut out. not enough cfm.
Old Oct 10, 2003 | 04:25 PM
AaronE's Avatar
AaronE
Unhappy
Really? The fuel pump's not big enough to satisfy sustained full load? For an amazingly well designed car, that seems to be a glaring omission...
Old Oct 10, 2003 | 04:27 PM
Davidsc4's Avatar
Davidsc4
My car act the same way twice at 130 mph. I don't why or is it gov regulation?
Old Oct 10, 2003 | 07:33 PM
LexAnt's Avatar
LexAnt
i think it's cuz you had ur OD off..... the OD acts as the fourth gear.... with that off you only gonna hit the speed you indicated at redline.... turn on OD at that moment and you should hit to about 150
Old Oct 11, 2003 | 12:14 AM
One HoT's Avatar
One HoT
CL Folding 10,000
Brian, what is not enough CFM?
Old Oct 11, 2003 | 12:48 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
pump flow rate
Old Oct 11, 2003 | 04:37 AM
VSsc400's Avatar
VSsc400
same reason why I installed a walbro 255LPH high pressure fuel pump... when you WOT you can hear the fuel pump going high pressure. downside is that it's pretty loud..
Old Oct 11, 2003 | 06:16 AM
Dimcorner's Avatar
Dimcorner
are the pumps the same for 1JZ cars?
Old Oct 14, 2003 | 11:18 AM
BAZ's Avatar
BAZ
The soarer's are two speed x2 voltages..[had all the info somewhere,ill try and dig it up!]
I thought it was the electronic resticter/govener that caused the revs to limit/die?
Old Oct 14, 2003 | 04:28 PM
PERRYinLA's Avatar
PERRYinLA
It's also possible the fuel filter is starting to clog up.
Old Oct 14, 2003 | 08:56 PM
Captain Bone's Avatar
Captain Bone
I really don't want to be an a-hole on this thread, BUT...
why travel that fast unless all by yourself and in a safe environment anyway?
I don't really see how its a "glaring omission" if Lexus decided to cut out at 130?
Sorry.. Just thinking about safety after my own stupid experience at high speeds, don't mean to bring you all with me.
-Anthony
Old Oct 15, 2003 | 02:26 AM
'S'Low Rider's Avatar
'S'Low Rider
LexAnt has the answer.
The SC400 is looking to change gear from 3rd to O/D after you reach 116mph with PWR mode ON. It obviously 'holds' a little longer than that allowing you to reach a higher speed but eventually the ECT says enough is enough and cuts the fuel.
We have the exact same problem with Japanese V8 Soarers running in the UK, they are 'factory' limited to around 118mph. Some owners have the factory limit 'delimited' but they experience the 'fuel cut' at around 128mph on full throttle, they have to back off a little and allow the transmission to change from 3rd to O/D and then they can continue.
The SC400 , as already mentioned, will let you keep going to around 150mph.
Old Oct 15, 2003 | 06:02 AM
Dimcorner's Avatar
Dimcorner
bummer....
Old Nov 10, 2003 | 05:50 AM
zokiz's Avatar
zokiz
That's too bad . . . just the other day I hit 143 mph in my sc300. It's stock with the exception of an Injen intake, z rated 18 " rubbers, and the eibach lowering springs. It felt like I could have went faster but there was a deadly curve coming up and I didn't feel to safe.
