Speedo, Tacho, and temp gauge don't work
That thread above covers everything that goes wrong with the 1992-2000 SC300/400 dash instrument clusters and how to repair them. The issues you are describing are very common and will affect most SC instrument clusters eventually so as to require capacitor repairs to the cluster gauge motors and in some exceptional cases a full replacement of an extremely severely affected gauge motor. Usually the gauge motors can be repaired and put back into normal service.
Alternatively you can contact Tanin Auto Electronix to send your cluster in to them to repair all the above issues you mentioned. They are specialists at repairing and upgrading our SC clusters and they also offer LED lighting upgrades should your original needle lighting be going out as well. Backlighting eventually going out and needle lighting eventually going out is also a fairly common thing with SC's at some point.
Additionally they also repair the LCD screens on the SC HVAC controller units and they can also replace all the capacitors in your main engine ECU if that service has never been performed yet (highly recommended as preventative maintenance before it becomes necessary anyway).
There are a number of things that could cause the gauges not to work, so we would be happy to take a look and do a full diagnostic on your cluster. As Kahn mentioned, this will help us find what is causing your issue and also determine other areas prone to failure where we can recommend some preventative repairs to avoid any other problems popping up in the near future.
Here is the link to purchase that service: 1990 – PRESENT LEXUS INSTRUMENT CLUSTER DIAGNOSIS & REPAIR
You can use coupon code "CLUBLEXUS5" for 5% off your total order.
The price for a diagnostic is $104.99. Once we determine what the issue is, we will give you a quote for repair and the diagnostic fee goes towards the repair cost total.
We also have a climate control repair/upgrade option available if you're interested!: 1992 – 2000 LEXUS SC300 SC400 CLIMATE CONTROL REPAIR
Please don't hesitate to message, call (262-456-4147), or email (contact@taninauto.com) us directly if you have any other questions!
TANIN AUTO ELECTRONIX
262-456-4147
www.taninautoelectronix.com
https://taninjdm.com/ Our Lexus LS430 Dealership
