Front/Rear SC camber kit...YAY!!
Just as a heads up, we should be receiving the Daizen 92-00 SC300/400 camber correction kits by the end of the week.
Also if there are any questions pertaining to the product, please post them here and I will try to answer them as best I can!
Todd Matsubara
TM Engineering LLC
www.tmengineering.net
Todd Matsubara
TM Engineering LLC
I was thumbing through the factory service manual the other day and one thing that caught my eye was that it appeared that camber is adjustable with the oem components. At least in front. Am I wrong?
It is fully adjustable via the lower arms, but only within a certain window. Each of the lower arm mounting locations (both front and back) have eccentric washer bolts that can adjust the camber/caster, but these cars (especially in the rear) have negative camber problems, especially so once they are lowered.
This kit basically adjusts the mounting for the upper arms, which allows you to have a new window of adjustment to try to get everything back into spec.
Todd Matsubara
TM Engineering LLC
Todd Matsubara
TM Engineering LLC
Originally posted by siniquezu
Is there going to be an adjustable camber kit for the coilover people?
Originally posted by DoubleWhoosh
Camber adjustment is separate and unrelated to which springs/shocks you have in the car. Too low of height simply causes excessive negative camber, which this kit fixes by a couple degrees.
Same kit for OEM and coilovers? I have to see pictures to believe this
