SC400 Swap
Old Oct 23, 2020 | 12:27 AM
benjamin31's Avatar
benjamin31
Default SC400 Swap
Hello, I am going to be purchasing an sc400, but the engine most likely needs to swapped because I believe the block and/or heads are warped due to overheating and blown gaskets. I am looking at an engine from a 92 sc400 with 100k miles, a 98 gs400 engine with 170k miles, a 95 sc400 with 200k miles and a 98 sc400 with 188k miles. I understand some of these engines are vvti while others are not. I am wondering how much work/money I would have to put into the car in order for the non-vvti or vvti engines to work with the stock ecu and harness. If anybody knows something I'd appreciate it very much. Most of the engines are around the same price of $560 ish.
EDIT: It's a base 1996 sc400
Old Oct 23, 2020 | 07:41 AM
ObSCessed's Avatar
ObSCessed
Hi you didnt mention what year the car you have is, that will be a big factor. Heres a brief timeline on the sc engine changes, 92-94 all compatible, 95 ecm changed along with a few minor things, from my understanding the 95 engine and ecm are only compatible with 95, someone chime in if im wrong though, 96-97 became obd2 compliant, and 98-00 have vvti. All that will factor into your choice.
Old Oct 23, 2020 | 07:44 AM
Tallyhoe's Avatar
Tallyhoe
Your question is sort of vague, you should first consider your model year, and what exactly you're looking for... Have you confirmed your engine is done? Have you gotten a 2nd opinion?? The issue is there are different ECUs for the same engine and different ECUs for the same engine and vehicles so accurately assisting you would be complicated at best... Stating your year will greatly help someone better answer your question.
Old Oct 23, 2020 | 08:35 AM
benjamin31's Avatar
benjamin31
Sorry about that, it's a 1996 Sc 400.
Old Oct 23, 2020 | 08:36 AM
benjamin31's Avatar
benjamin31
I have gotten a second opinion on the car, they suggested swapping the engine. Sorry about my vagueness, it's a 1996 sc400.
Old Oct 23, 2020 | 01:47 PM
Tallyhoe's Avatar
Tallyhoe
My understanding on these older platform, as I'm still new to this.... I'm pretty sure you can swap in a later version of the engine, like the 98 and newer VVTi, but you will need the harness and ECU to come with the engine. You may need to research further if it will work with your instrument panel.
Old Oct 23, 2020 | 03:03 PM
benjamin31's Avatar
benjamin31
I see, thanks for your input.
Old Oct 23, 2020 | 03:19 PM
Tallyhoe's Avatar
Tallyhoe
Might want to wait for a more experienced member for better guidance.
Old Oct 23, 2020 | 03:30 PM
That is correct to use a VVTi engine you will need the entire engine harness and ECU, and this will have to be custom spliced to interface with the existing harnesses in the car. Unless you an expert in wiring, electronics and electrical work in general don't attempt this.
Qwertybnz
Oct 23, 2020 12:25 PM
Sanfou510
Feb 11, 2016 08:02 PM
sgunitkc
Dec 12, 2011 10:40 PM
jlexus95
Dec 18, 2010 05:51 PM
sckidnyc
Nov 23, 2006 11:24 PM
