Battle Version or Titan
Last question before I order parts. Does anyone have any good, bad or indifferent ideas towards these two brands and their rear subframe mounts.
Switching over to TT sway bars and obviously need the mounts. The BV are 375 and the Titan (and Powerhouse) are like 280 or so. Not sure if it is worth it to spend the extra money for BV. The Powerhouse mount directly in the center where as OEM comes a bit offset like the BV and Titan. I read some posts on another thread about these and apparently some people have trouble getting certain mounts to fit but it appears it is mainly 97+ years with this problem, mine is a 94.
Also, the TT sways I got came with the u-brackets, bushings, hardware and end links. Will the stock end links work or will I meed to buy longer adjustable ones? And if so what do people run?
Thanks in advance, cheers!
Conceivably someone could just fabricate up their own metal plates, tap them for the right OEM bolt threads and weld them onto the SC subframe mounts if they knew exactly where to place them and if they could do it perfectly on each side. I'd only trust something like this to a very skilled welder however. If such a thing were to be done you'd want to make sure those mounting locations will be solid for all eternity.
But if you do not have a very skilled shop who knows what they are doing to make such a modification happen I'd go with any used OEM Supra or aftermarket off the shelf option. As I mentioned in the other thread the mounting point differences between the BV and
97+ model years having trouble fitting rear subframe mounts is news to me. There should be no major differences back there but that is possible since 1997-1998 was one of the biggest updates to these cars during the full production run.
It could also have to do with any OEM subframe mounts having rubber to give a little leeway when installing them while any aftermarket solid mounts will have to go in very precisely since they have no rubber or polyurethane in them to offer any give upon installation at all.
As for the end links I don't remember offhand (it has been so many years since I did this) if the Supra MKIV end links are needed or if SC end links will work. When I installed my Supra TT rear swaybar I think I left on the MKIV end links so it's more than likely those which you will need. I think that PDF document you posted in the other thread tells if you need them or if you can re-use your SC end links.
Last edited by KahnBB6; Jun 19, 2020 at 12:56 AM. Reason: Correction: PHR not Titan
Titan
Battle Version
Thanks in advance!
Sorry last question not sure if you know, how many solid steering rack bushings do I need to replace mine? 2? I was going to get them from figs
I have battle versions on my car, they had to be drilled. I didn't think that was right, so I ordered titans and the same issue was there. They would have had to be drilled too. The thickness of the base and the width of the bolt holes on the oem mounts make it possible for a bolt to go into place if you were to force it. With the solid mounts, the base is about 5x thicker, so a slight crookedness gets multiplied as you get further away from the base. My advice would be to try and buy them new from the dealer. It should be similar to the cost of solid.
As far as the endlinks go, SC ones will work, but you'll want custom endlinks that are shorter. I would go with figs engineering or battle version.
Steering rack bushings - the solid mounts only replace the 2 bushings on the driver side of the car, but not the clamp style bushing on the passenger side.
But if you do not have a very skilled shop who knows what they are doing to make such a modification happen I'd go with any used OEM Supra or aftermarket off the shelf option. As I mentioned in the other thread the mounting point differences between the BV and Titan solid mounts made me concerned just because Titan deviated their design's mounting a bit from Toyota OEM spec but that may or may not make a difference. I also would like to hear thoughts from others on this.
*Edit* here you go Kahn https://www.clublexus.com/forums/sc-...ml#post9759947
Blkexcoupe-- Thank you for that link to Boergy's custom mount DIY! I had completely forgotten that he documented that
And the notes about how the solid mounts are drilled which requires them to be re-drilled are invaluable.
I will link another thread on here I found of people discussing this and one person said the Titan mounts went on no problem but obviously others had issues but there seems to be a brake line issue as well with the Titan mounts but that shouldn't be too hard.
https://www.clublexus.com/forums/sus...s-install.html
Again, thanks in advance from everyone for all the help!
That thread confused me when he originally posted it because my friend bought my titan mounts around the same time, and he had to drill them out to fit his 97 SC also.
I didn't have any issues whatsoever installing them. I didn't have to drill any holes larger. HOWEVER, it was a nightmare taking the old mounts off. One was seized(rust) to the subframe peg.
The issue(s) i did run into with the Titan mounts, and also what I've seen people mention with the BV (I assume the PHR as well), was that you don't want to reuse the oem bolts because they're now a bit short in length. The billet mounts are thicker, and because of this you will need bolts that are xx mm longer to compensate for this. Also, because the holes in the billet mounts are oval shaped, I also bought thicker, wider washers to increase the clamping surface area of the bolt heads. So in the end, I bought 8 bolts that were (width of mount + width of thick washers in MM) longer.
I noticed right away that OEM mounts are offset for the swaybar, which was the reason I avoided the PHR mounts altogether (they are centered, most likely to save on costs) and limited my choices to the Titan or BattleVersion. There's a reason Toyota designed them that way.
For your final question, I have BattleVersion endlinks. They are adjustable and those were compatible with the both the original SC swaybars and the DoLuck JZA80 bars I have now.
EDIT - I see you're also asking about steering rack bushings. I have the Daizen on mine and when they eventually go bad, I'll be replacing them with Figs SuperPro poly. I do not recommend solid rack bushings for the street. They are great for racing applications but on the street you're gonna want some movement in the rack to avoid damaging it, like when you hit potholes or uneven pavement. The stress is amplified because the solid bushings only go on one side, which just puts even more pressure on the rack itself. There is one guy in the SC300/400 Mods groups who said solid bushings on his street drifter is why his rack cracked. He swapped in another rack but this time put in poly
I did read your thread on it and upon re-reading it, it appears to be more involved than I thought. You said having a hammer out 1 side to make them fit, plus drilling out the hole (do you have to tap it as well?) and I'm pretty sure I'll have to relocate a brake line or something back there as well? I also saw you said you hated them when you got them, did you keep them or get the OEM ones? I'm not sure if it's worth the work if it the OEM will still fit and will be easier.
Thanks in advance!
Thanks in advance!
The hammering was because of how the billet mounts are designed. They left the edges larger to save on machining instead of following the oem mounts. The brake line will have to be removed, but you should be able to put it back in after the billet mounts are installed.
I ended up keeping them and swapping the coilovers out to KW v3.
Anyways, back to the reason I went to look for this thread. I pulled the mounts off my 93 TT subframe to shoot some comparison pictures
TT on top, my old 98 SC300 mounts on the bottom
If you notice on the mounts, the distance between the holes on the left (tt) is larger than the right (SC3)
This is the SC3 mount placed on top of the TT mount. If you look at the bolt hole on the right, it would have to be widened on the TT mount to match the SC3 mount.
