Motor/Trans Mounts
Old Feb 27, 2020 | 07:21 AM
DubsackDev's Avatar
DubsackDev
Default Motor/Trans Mounts
Hey all,
New here and I know this has been covered in threads before but just clarifying for myself.
I'm looking for part numbers/links for TRD motor and trans mounts for '94 sc3 5speed as well as part numbers/links for polyurethane motor and trans mounts.
Also, there is RHS, LHS motor mounts and is there just 1 trans mount?
Thanks in advance!
Old Feb 27, 2020 | 08:21 AM
RudysSC's Avatar
RudysSC
I installed the Xcessive poly engine mounts on my SC3 and I've grown to love them. They were a little too stiff at first, but softened up nicely after a month or so of driving. Right now I have a new OEM trans mount, however, there is only one and they're available in poly from Xcessive as well I think. As long as you select the right transmission you should be able to get the correct part without any problems.
Old Feb 27, 2020 | 11:13 AM
1997Soarer's Avatar
1997Soarer
The TRD engine mounts are on ebay shipping from Japan. They are completely out of stock here in the USA. Disclaimer: To use the TRD JZA80 engine mounts, you need the JZA80 engine mount brackets. You can't reuse your SC pieces.
There is a TRD trans mount for the JZA80 but it only fits the V160/161 trans.
Other companies that make engine/trans mounts for SC/Soarers:
Kazama
engine mounts https://www.kazamaauto.co.jp/product..._engine_mount/
Vibra-technics
engine mounts https://www.vibra-technics.com/toyot...k3_lexus_sc300
Xcessive Manufacturing
engine & trans mounts https://xcessivemanufacturing.com/to...uspension.html
trans mounts for transmissions https://xcessivemanufacturing.com/to...nsmission.html
Megan
Engine mounts + auto trans mount https://meganracing.com/catalog/prod...s/mrs-lx-0540/
W58 trans mount https://meganracing.com/mrs-ty-1441-ii
**The Xcessive site can be a bit complicated because the first mount they sell is more of a replacement crossmember brace so you reuse your OEM trans mount. They offer urethane mounts for individual transmissions on the Toyota transmission page
Old Feb 27, 2020 | 03:07 PM
DubsackDev's Avatar
DubsackDev
'Preciate you both, ended up going with the Excessive's.
Cheers!
Old Feb 28, 2020 | 06:46 AM
RudysSC's Avatar
RudysSC
Great choice, I don't think you'll regret it!
DshngDaryl
Sep 23, 2017 09:28 AM
bdelong36
Feb 17, 2011 08:51 PM
forcefed86
Nov 3, 2008 10:30 PM
