Black plastic under engine
Old Nov 23, 2009 | 09:40 PM
  #31
salimshah's Avatar
salimshah
25 Year Member
I counted 5 in front 3 on each side and 4 for sure and maybe 5 on the back. For the back the two holes are almost at flat surface (near center of the rear edge and few inches apart) the the other are molded about an inch deep. I cut out the edging to about 3" square and used them as large washers. [swapped with the longer bolts from the front]. A bit ghetto, but definitely not visible and still functional. Beats the $100+ proper solution.
Salim
Old Nov 23, 2009 | 10:04 PM
  #32
masagsxr's Avatar
masagsxr
Post pix Salim..... I have the OEM ones and for sure there are no holes on the back and nowhere it lines up anywhere to be bolted. There is one tab about 1-2" that supposedly you can slip in to rest by the subframe that is no help because as soon sa you drive the car, it'll sag again.
shikbas
Automotive Care & Detailing
Mar 21, 2011 08:43 PM
azsc4001
Jun 25, 2007 03:09 PM
BottomsUp
Oct 8, 2006 08:19 PM
JessePS
Oct 2, 2006 07:36 PM
Steve Barnes
Aug 30, 2002 12:35 AM
