AFC Throttle Position Percentage
Old Aug 9, 2003 | 08:08 PM
aliga's Avatar
aliga
Former Sponsor
Default AFC Throttle Position Percentage
I noticed something strange while looking at the afc throttle percentage today. I was driving the car and punched it and saw the throttle percentage go to 80%. I then held the pedal at the same position, and noticed the throttle percentage decreasing.
Should the display not have remained at 80% or higher?
Thanks.
Old Aug 10, 2003 | 07:18 PM
Hermosa's Avatar
Hermosa
While you think you were hitting it constantly I am pretty sure that your body and foot were slightly being leaned back ever so decreasing the pressure you were exerting on the accelerator at that throttle percentage. If you hit 100% throttle and see it falling then I would worry about it. How much difference was there? In other words how many %throttle per second was it dropping?
Old Aug 10, 2003 | 08:07 PM
lilnard85's Avatar
lilnard85
while we are talk about it i need a new throttle position sensor where is it at.thanks guys
Old Aug 11, 2003 | 10:53 PM
sweetsc400's Avatar
sweetsc400
Do you drive a 300 or 400 lilnard? I have a 400 and it's on the throttle body facing the front of the car.
Old Aug 12, 2003 | 03:25 PM
lilnard85's Avatar
lilnard85
oh yeah you would need to know what kind of sc i drive i have a 400.
Old Aug 13, 2003 | 07:56 PM
aliga's Avatar
aliga
Former Sponsor
I did some more investigating today. I did the sensor check on the afc, and got the following values:
sensor check:
@ 0 throttle = .5 volts
@100 throttle = 3.75 volts
I know I have the right wire tapped, I read somewhere the tps voltage ranges from 0-5 volts.
Could it be a bad afc?
Old Aug 14, 2003 | 08:41 PM
SC300T's Avatar
SC300T
I noticed the same basic thing on my SAFC2. Oddly enough, the AVC-R attached to the very same wire reads more correctly... I don't know what could be the culprit. It's sort of frustrating, since the AVC-R reads more correctly, I'd have to assume that the problem lies within the Apexi stuff.
I noticed that on a long trip, even the AVC-R would even read wrong after several minutes, the indicated throttle position would gradually migrate readings until the throttle is completely released, then it corrects itself.
My guess is that since these two boxes don't have a calibration function, that its the self adjusting internal circuitry that is causing slight errors. Sort of a design flaw, IMHO.
Helogadget
Mar 14, 2025 02:35 AM
Cp2295
Nov 26, 2016 12:24 AM
draco
Mar 4, 2013 05:20 PM
Suneet
12
Jun 7, 2007 11:33 PM
