getrag transmission
Old Aug 6, 2003 | 09:09 PM
reamemiya's Avatar
reamemiya
Default getrag transmission
how much does the getrag transmission swap cost on a sc300 with a 2jz-gte swap with all required modifications? anyone got any info?
Old Aug 7, 2003 | 07:52 AM
SinisterSC's Avatar
SinisterSC
The transmission itself will cost you anywhere from 500-1800 bucks I'm guessing. With the trans swap, you will need change over to a longer drive shaft and you want to get a Supra TT rear end also to make things easier. That's all I really know. But use the Search button, it works wonders on this site.
Old Aug 7, 2003 | 03:16 PM
reamemiya's Avatar
reamemiya
not bad not bad...any more info ?
Old Aug 7, 2003 | 06:08 PM
Angel's Avatar
Angel
I believe the tranny will cost closer to $2300-$3000.
Old Aug 8, 2003 | 07:12 AM
Onelove's Avatar
Onelove
You are correct. Lets not forget about another 1000 for a clutch and flywheel setup, plus driveshaft, rear-end, etc.
Old Aug 9, 2003 | 08:11 PM
bmsport's Avatar
bmsport
PHR charges $5000 and i don't think thats too bad of a deal. If you did it all yourself, hunted down all the cheapest parts, it would cost you like $3800/min.
Old Aug 10, 2003 | 12:46 PM
motorheaddown's Avatar
motorheaddown
I've done the swap and it ran $5k. That's for parts only. I did all the installation meaning that a swap from a tuner will run a *whole* lot more.
PHR's price has been brought up before. I've delt with Jarret in the past. You'll *never* get a full 6-speed swap for $5k.
-scott
Old Aug 10, 2003 | 01:14 PM
TurboSC's Avatar
TurboSC
I got my 6-speed, motor, ecu, uncut harness, driveshaft and everything else I needed for well under $5,000.. I got lucky.
Old Aug 10, 2003 | 07:34 PM
bmsport's Avatar
bmsport
I haven't been on their site for a while, but i always thought that $5k was low for that upgrade. I got my 6 speed + lsd + driveshaft all with my clip which i paid $6k for. If your gonna do the getrag swap, you might as well spend 5k on a clip and if you dont want the motor, sell it along with all the other little parts for about $3500 and essentially get the trans and stuff for $1500.
Old Aug 10, 2003 | 08:28 PM
TurboB6's Avatar
TurboB6
I've talked to Jarrett numerous times. He usually goes by the "going rate" of items with might be 5K total or more than 5K. Everyone should know by now his prices aren't always set in stone on used parts.
JCE102JZGE
Performance
Jan 27, 2006 12:11 PM
LexywannaB
Jun 18, 2004 12:12 PM
Baby ///M3
Dec 6, 2003 09:03 PM
reamemiya
Jul 2, 2003 06:11 PM
bluegreygs300
Performance
Mar 28, 2002 07:03 PM
