Hi guys! just picked up an sc300 a few weeks ago and trying to figure out some issues..
So my map, dome, floor and driver, mirror light and driver side door light are not working. Fuses under dash and in the engine bay are good. Sunroof works, clock works. Open door warning light on cluster works. The driver side sun visor is missing. Is there something that call be causing these lights not to work? I have searched here and have only find people on the SC forum have bad fuses. Someone on a later model GS had an issue like this and someone said it was the door ecu causing this. Could this be my problem? thanks for the help, i have searched a lot before creating this thread. Thanks again.
What year what year is your SC could also be your master door switch as well and have you check for power at any of the dome lights with the test light
