Suggested maintance on my 1999 SC400 200k miles
Okay I know I have to change the valve cover gaskets they are leaking. I changed the oil, new air cabin air filters as well as engine air filter element, fixed the tilt steering was stuck and would not tilt down. Replace the broken power antenna yet to put it back in the car. Replaced the power steering fluid, topped off the anti freeze, as well flushed out the brake fluid. Next is rear end fluid and transmission fluid/new filter. What do you guys use to reseal the fog lamps my driver side is filled with water after I washed the car. I see on the forum that front lower control arms need to be replaced as well. So what other items need to be replaced. My driver side window does not go up or down Im guessing it the regulator nor does the lock work using the lock switch. By the way the timing change/ water pump/ plugs were done at 155 miles. I need to find someone in the metro Atlanta area to fix the window and lower control arms....dont want to deal with those two issues. Thanks in advance
