Question about door hinge
Old Jul 26, 2003 | 12:04 PM
buuzy's Avatar
buuzy
Default Question about door hinge
Hey guys, are you guys' doors open smoothly all the away out or is there a slight kink halfway through. Mine seems to half a very slight drop when it's halfway opened. Also, my doors are very difficult to shut tight unless I slam it with a lot of pressure. Are my hinges shot or is there some adjustment I can make?
Old Jul 27, 2003 | 06:11 PM
FireCode's Avatar
FireCode
I have a similar problem and was wondering if there was a fix
Old Jul 27, 2003 | 06:17 PM
aliga's Avatar
aliga
Former Sponsor
hinges are shot. you can rebuild them or get new ones.
there is a article on rebuilding them, do a search for it.
Old Jul 27, 2003 | 07:40 PM
bizzy928's Avatar
bizzy928
Here you go:
http://www.jkwebdesign.co.uk/lexusclub/doors.htm
However I say just get new hinges.
Old Jul 27, 2003 | 08:10 PM
nextlevelcoupe's Avatar
nextlevelcoupe
it's my turn to do my doors as well..........where is the best/cheapest place to get the parts needed?
Old Jul 27, 2003 | 08:50 PM
buuzy's Avatar
buuzy
Hmmm... according to intellexual, a new hinge is $400 from deal. Ouch! That's for ONE hinge. I think I'll just continue to use my arm strength. Or get a used one from the junk yard.
Old Jul 27, 2003 | 09:21 PM
bizzy928's Avatar
bizzy928
Unfortunately most used hinges suffer from the same problems.
Old Jul 27, 2003 | 10:08 PM
siniquezu's Avatar
siniquezu
Unfortunately, if the hinge sags too much, the door clips the fender. Damage goes to the door and the fender so it is best to replace the door hinge ASAP. You COULD put a shimmy in it and boost it up a bit because of the sage, but the door won't fit perfectly and closing it will be a *beyuch.
Old Jul 28, 2003 | 04:32 AM
aliga's Avatar
aliga
Former Sponsor
You guys could do the following if you do not replace the hinge. Loosen up the fender bolts, and move the fender 1/8-1/4" towards the front bumper. This will give you more clearance until you replace the hinge..
Old Jul 28, 2003 | 11:05 PM
siniquezu's Avatar
siniquezu
Yeh, but you will notice a giant gap, a fender that isn't flush with the hood, and funny fitting screws on the bottom of the fender.
Old Jul 29, 2003 | 05:59 AM
aliga's Avatar
aliga
Former Sponsor
Trust me, you won't. I did it on mine (both sides) and it looks aok.
Old Jul 29, 2003 | 06:53 AM
nextlevelcoupe
i'm in the process of restoring my car and will be replacing both of my hinges next week.
i am always getting complaints on the weight of the door and to close the door you have to be a little forceful-also makes a little knock sound from the hinge when fully extended.
Old Jul 29, 2003 | 09:58 AM
Pen's Avatar
Pen
Apply white lithium grease to the door hinges, seems to take a few applications to work in well, makes them work nice and smoothly again - mine took a few weeks to really work well.
Put a jack under the open door, release the door hinge mounting bolts a bit, raise the jack, tighten the bolts to get a better alignment and easier door closing.
Report back with results :-)
Old Jul 29, 2003 | 12:07 PM
hansjl's Avatar
hansjl
Ditto on the white lithium grease to the door hinges and the socket type depressions where the stops are. The white lithium grease is kind of messy but if applied through the plastic straws, manageable.
Old Aug 5, 2003 | 05:17 PM
THE_CEO's Avatar
THE_CEO
yes the white grease works wonders....
CEO
Dx3
Nov 23, 2004 02:39 PM
ChronoJ1
SC400 / 300 Classifieds
16
Nov 20, 2004 02:51 PM
spaceman
Nov 19, 2004 06:39 PM
kamlex
IS - 1st Gen (2001-2005)
Mar 5, 2002 12:23 PM
