VPC Documentation
Old Jul 11, 2003 | 12:22 PM
aliga's Avatar
aliga
Former Sponsor
Default VPC Documentation
7 pages of info:
http://www.alltrac.net/manuals/HKSVPC.html
Gazi
Old Jul 11, 2003 | 08:47 PM
gadgetSC's Avatar
gadgetSC
This is helpful too
gadgetSC-t
Old Jul 11, 2003 | 08:59 PM
aliga's Avatar
aliga
Former Sponsor
Does anyone have a higher res picture of the following vpc + afc:
Old Jul 12, 2003 | 04:21 AM
gadgetSC's Avatar
gadgetSC
Gazi.....that last one is pretty much the same as that messy hand drawn job I posted. I much simpler. I believe this originated from DaveH. It does work and was the most helpful, for me.
gadgetSC-t
Old Jul 13, 2003 | 10:08 PM
lilnard85's Avatar
lilnard85
guys this may sound dum but that is the vpc andwhat does it do, thanks
Old Jul 14, 2003 | 04:25 AM
gadgetSC's Avatar
gadgetSC
lilnard.....The VPC is designed to physically and electronically replace OE air metering devices which present a significant restriction to the intake system and offer no adjustment or reprogramming options to take advantage of dramatically higher air flow or larger fuel injectors. The VPC converts both air flow meter and air mass sensor systems to what is referred to as speed density systems by utilizing a 16 bit central processing unit reading its own intake air temperature sensor and absolute pressure transducer (B-MAP sensor) signals.
This unique conversion feature allows the VPC to completely replace the factory air flow metering device. Another benefit of the VPC is the ability to create your own programs to take advantage of larger fuel injectors and larger turbos.
gadgetSC-t
Old Jul 14, 2003 | 08:24 PM
lilnard85's Avatar
lilnard85
Thanks so it makes the lexus faster lol but i got ya.
Old Mar 25, 2006 | 05:11 AM
chidoks's Avatar
chidoks
aliga or gadgetsc, can one of you guys pm me your number? i have a problem with my vpc installation and i need to figure out which wires the resistor in the maf goes to. the diagram only shows it for the supra.. sc wires are different. thanks
Joss350
Performance
Jul 18, 2013 11:34 AM
cgholson
Jul 17, 2008 05:28 PM
1sxyrxy
Sep 8, 2007 09:25 PM
Jrezo
Performance
Jun 11, 2007 01:11 PM
