Drivers side door not locking or unlocking...Whats wrong with it?
Old Jul 10, 2003 | 10:24 PM
Skulinex's Avatar
Skulinex
there is a link to a site with instructions, part number <I think it's just a little white plastic piece> and pictures.. it was post a looong time ago.. Ill try searching see if I can find it
Old Jul 11, 2003 | 12:52 AM
MikeysSC's Avatar
MikeysSC
My passenger side door isnt working either. If i try to let my window go down all the way it sounds like its hitting something. . . so can you find the link for us! Thanks!
Old Jul 11, 2003 | 10:05 PM
asfaltsurfer1's Avatar
asfaltsurfer1
Yeah mine has had the EXACT same problem for about 6 months now, seemed like it would come and go with no reason. Yesterday while replacing my window guides I decided to check out the problem expecting it to be operated by a solenoid. I removing the unit at the back of the door which controls the lock and closure ( not sure what to call it ) and then disassembled it. There is a motor inside this unit which drives a worm gear to lock and unlock. This motor seemed very week so I decided to investigate further. Upon disassembly of the motor I discovered that the brushes were VERY worn and the motor was filthy. I then re-surfaced the brushes, cleaned / sanded the armature and reassembled it. This did the trick. My drivers side lock now operates faster than the passengers side!! I’ll worn you this was a quiet complicated process and took about 2 hours to complete. I don not believe the motor is sold separate, only as a unit which I’m sure is quiet high. Contact me if you have any ?? on the process contact me and I’ll do my best to walk you through it.
gulleyman
GS - 1st Gen (1993-1997)
15
Sep 19, 2021 08:05 PM
greg3852
Nov 30, 2019 08:04 AM
Drcoffee
RX - 1st Gen (1999-2003)
12
Jun 13, 2016 07:46 PM
krawfo
Jul 25, 2012 05:14 PM
LS_4Will
Nov 13, 2004 09:41 PM
