Hi all electrical problem here
Old Nov 14, 2017 | 11:54 PM
Armymanmik's Avatar
Armymanmik
Default Hi all electrical problem here
Hi guys I'm Mike, I'm from the UK but currently live in Germany with work. I have just purchased a soarer 1992 tt model . Love the car apart from one problem, it has newer rear lights on it and I've been told it has been missed to fix the hyperlink issue, but my indicators still flash rapido. And I keep blowing indicator fuses, any one have any ideas? Hazards still flash normal
thanks
Old Nov 15, 2017 | 07:00 AM
BiGEZ's Avatar
BiGEZ
https://www.clublexus.com/forums/per...ht=hyper+blink
Check out the above link and see if that helps.
Old Nov 15, 2017 | 07:05 AM
logix7's Avatar
logix7
does it have the correct wire harness for the newer lights? are they LED bulbs? need more info
Old Nov 15, 2017 | 08:51 AM
Armymanmik's Avatar
Armymanmik
Default Ok where I'm at now
Yes all bulbs no led s . And yes has the correct harnesses. I've found out that there's a dodgy earth or something is shorting out . I've found all bulbs and holders are good and it's something under the drivers footwell/ fuse panel bit. Any one ideas?
Old Nov 16, 2017 | 02:30 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
The aussies have lots of info on the tt soarer. Check planet soarer.
Old Nov 26, 2017 | 09:17 PM
tomr51's Avatar
tomr51
remove the flasher unit (side panel near accellerator). Increase the value of the large electro cap in the flasher unit. I cannot remember the values but maybe replace the existing cap with an 8.2uf
NickawdIs
Aug 14, 2012 11:17 AM
BLK13X
Lighting
Sep 3, 2003 11:07 AM
shoyu
Feb 5, 2003 11:18 PM
