Engine Mount Choices for the GTE swap?
I'm still a little foggy on what engine mounts to use when i do the GTE swap. Usually in other cars i would just throw in some stiff poly mounts, but apparently no one uses them on the supra/lexus. Short of going with phr solid engine mounts, is there any alternative? What did you guys who have done the swap use.
ps: i will be running a t78, on low boost at first. Thanks ahead of time.
I used the supra TRD motor mounts. The material their made of is a bit stiffer and more durable. I didn't notice any difference in engine vibration. New, there only a bit more than stock ones. Either ones will do the job though.
Call Curt up at Elmhurst Toyota 630-279-2265
Chris
Chris
