another timing belt question...
Old Sep 13, 2017 | 09:08 PM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
Default another timing belt question...
i got a price of $750 at the toyota dealer for the timing belt and water pump and the tensioner and bearings. (no cam seals) for my 93 sc400 labor only.i bought a aisin kit at amazon.I get 10% off military discount.so the price is about $700 after tax.Is this price in line of what others paid?
i have 117k miles and its the second belt job.first was 2004 with 61k miles.thanks all!
Old Sep 14, 2017 | 05:47 AM
super400's Avatar
super400
I just payed about $2,300 to get my timing belt and water pump replaced. Granted I had to do a few more things too but it sounds like a good deal.
Old Sep 19, 2017 | 05:23 PM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
i returned the amazon kit and bought the water pump at the toyota dealer.night and day difference between the two in quality.The same with the lexus timing belt.bought a timing belt tensioner at the toyota dealer also.Getting it changed thursday.
i am not changing any of the bearings or the cam seals.
Old Sep 30, 2017 | 12:52 AM
BsRodeo7s's Avatar
BsRodeo7s
If you're changing the timing belt and water pump you should go ahead and change the crank seal and cam seals. You've already got everything apart, and the seals are an easy change.
Old Sep 30, 2017 | 07:35 AM
LEXXIUM's Avatar
LEXXIUM
+1 I'm with rodeo, I would also do cam seals, if you don't do it at the time of the timing belt, you'll be doing a timing belt job twice later!!!
i got a timing belt kit by gates, includes tensioner, belt... ok quality
Old Sep 30, 2017 | 04:15 PM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
update:I received my car back 9 days ago.When i dropped it off at the dealer my car ran like a Swiss watch,But when it took it home it was a little noisier then before and with the a/c on it was even noisier.I returned the car and the tech said, its nothing he did.So i drove it home and for a few days i lived with the noise.
Then on one trip to the store. i started it up and the trac and engine light was on and the car was in limp mode,So i returned the car again.the tech didnt get any codes.started the car and the lights are off.Tach said he will trouble shoot at hourly rate,$120 hour.I decline.
i took it home and find the alternator making the noise as best as i cant tell.it gets louder when the a/c is on.So i have a alternator on order.i am thinking the load when a/c is turned on is the problem.i will keep you all updated after i put the new alternator in.Fingers crossed! Ps,When the car is cold the noise is gone after 10 minutes or so it returns.Its a groaning sound.I had the alternator benched checked and it checked fine but they only checked it for maybe 1 minute.
Old Sep 30, 2017 | 06:54 PM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
The parts that were changed at the dealer was timing belt and tensioner.Water pump and both buttons (they were cracked) and the thermostat and serpentine belt.I also had both motor mounts changed.
Old Oct 2, 2017 | 06:57 PM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
Talking
Well the alternator was the problem.Back running like a Swiss watch again.
Old Oct 2, 2017 | 10:13 PM
BsRodeo7s's Avatar
BsRodeo7s
Default Gates timing belt
I like the gates, I got the timing belt/ water pump kit. It came with hydraulic tensioner, and seals and gaskets that I needed, plus Gates is a good belt. I had to swap out my 2jz-ge motor because the previous owners didn't maintain it at all. So the cost of the motor swap was cheaper than trying to fix all the problems. I changed out parts on the engine stand, did the timing belt/water pump, cam and crank seals and tranny input shaft seal. Got the motor swapped out within a week. Lot of work but my motor's like new. Cost about $2,000 with a used motor from Japan... 70,000 mile compared to my old at 268,000.
Old Oct 2, 2017 | 10:27 PM
BsRodeo7s's Avatar
BsRodeo7s
Default Timing belt cost
$750 seems high, my timing belt took about 3 hours to change out. My dads sc400 took about 12 hours because of all the parts on that damn 1uz-fe engine. They quoted my dad $750 for timing belt/water pump without the hydraulic tensioner. After doing it though, it really wasn't that bad... just time consuming, but it's never easy with dads cars. Ended up changing cam and crank seals... I always do with timing belt change... oil change(synthetic oil), flush fluids, tranny filter and gasket and flush, new struts all the way around, new tie rods(inner and outer), front brakes, paint all brake calipers, new ignition coils, spark plugs, wires, distributor caps and rotors. Saved dad about $2,500 on labor. I love these SC's.
Old Oct 3, 2017 | 05:23 AM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
Sounds like your dads car is ready for another 100k miles.
i paid $1100 labor for the timing belt,water pump and tensioner also the engine mounts.the parts that they added was 2 buttons, thermostat and shop fees and other blown up prices.i spent $350 or so in parts.$1500 to the dealer.i paid $350 for the alternator and changed it myself so a total of $1850.
Old Oct 3, 2017 | 10:30 AM
BsRodeo7s's Avatar
BsRodeo7s
Default Total
our total for all those parts was about the same as what you spent. Imagine what the dealer would have charged... probably saved $3-4,000. I had to swap out the engine on my SC300. Those motor mounts cost around $100 each, but they made a big difference. One had completely come apart, but the car had 260,000 miles on it from previous owners that did not maintain it at all. I saved my SC. Now I just need to paint it, which I'm still debating on the color. Maybe I'll make it a candy apple red, I really want a cobalt blue, but since I'm doing it myself, it would be a pain to take out the interior to paint the entire car, and it's stock red now. Plus I wanna throw on a body kit. This is a car that I wanted when I was 22 and they came out. It's really a nice car, with timeless styling. Love that body shape. I hope that some day I'll end up with an LFA. Glad your SC is running well again.
Old Oct 3, 2017 | 11:15 AM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
Here are a couple pictures of my sons 93 sc300 with 68k miles then,Two and a half years later he has 84k miles on it.
his car is never clean and mine is always clean.LOL
Attached Thumbnails another timing belt question...-pa020262.jpg   another timing belt question...-pa020261.jpg
Old Dec 27, 2019 | 07:48 PM
Dubbayoo's Avatar
Dubbayoo
For metro Atlantans I personally recommend LexusTechsofAtlanta in Johns Creek and Decatur.
PPJ
19
Dec 17, 2012 05:48 AM
Jace_91
Jan 8, 2010 07:29 PM
sktn77a
RX - 1st Gen (1999-2003)
15
May 17, 2009 12:42 AM
skippy911
Jan 28, 2007 07:23 PM
Felix gs43
Performance
Oct 8, 2006 10:31 PM
