Engine noise around 60MPH
Old Jun 30, 2017 | 10:31 AM
tooshin's Avatar
tooshin
Default Engine noise around 60MPH
Hi guys, i have 2000 SC300 with 112,000 Mile on it. i drive her mainly on cruise control for going to work and come back home. recently i noticed a rhythmic reeving noise coming from the engine. it happens while i am driving on a constant speed around 2000 to 2300 rpm or 58 to 63 MPH. the rhythmic noise is at most around 2100rpm using the cruise control. if i park the car and place it neutral and rev around that same rpm then i dont hear it but i only herar this noise when i am driving. i do have a engine trouble code but it was determine to be a EVAP system and recommend charcoal canister replacement with vacuum switch valve. is this related issue?
Old Jun 30, 2017 | 12:28 PM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
it maybe something simple as a v belt.
Old Jul 2, 2017 | 08:12 AM
t2d2's Avatar
t2d2
Is it only at that rev range or only at that speed? Have you tried dropping it out of overdrive to change the RPMs at the affected speed and see if the sound goes away?
ES350Bob
21
Jan 20, 2022 12:25 PM
anniversar
Nov 23, 2013 06:10 AM
l33cher
Aug 22, 2011 04:57 AM
kate
Jan 23, 2006 03:48 PM
nsane_IS
IS - 1st Gen (2001-2005)
Apr 8, 2002 07:36 AM
