92 SC400 ABS noises
Old Apr 12, 2017 | 12:59 PM
Returd's Avatar
Returd
Default 92 SC400 ABS noises
I'm getting noises from my ABS unit, usually on start up. Lasts about 30 seconds and I can feel pulsation/vibration on one of the lines on the top of the unit.
I had very few miles driven before i did a caliper swap (stock0 and bled the brakes back in.
I'm not sure if i somehow pulled a bubble into the ABS or if my caliper work was just a coincidence.
How difficult is it to bleed the ABS?
is there some other ABS issue i should be looking into?
Is there further info I should gather to better diagnose the problem?
Old Apr 17, 2017 | 08:28 AM
Returd's Avatar
Returd
so can anyone point me to a "how to" for bleeding the ABS?
Old Apr 17, 2017 | 09:37 AM
Returd's Avatar
Returd
Oh additionally. When my ABS system starts making this cavitation noise I've felt pulsation on this tube.
Old May 9, 2017 | 04:29 PM
Returd's Avatar
Returd
I replaced a leaking hose from the accumulator and took the car to a local dealer for bleeding. They couldn't get a bleed completed and trouble shot to the Trac pump. I'll be pulling the parts car pump. That car hasn't run in a while so I'll try to get started and make sure I don't get a trac pump light from that car. If good I'll swap it out. Bleeding could be an issue.
Jkallinen
Dec 19, 2018 11:50 AM
jayr1
Jul 7, 2014 05:00 AM
KimShep7
RX - 1st Gen (1999-2003)
32
Nov 1, 2011 08:53 PM
jjason981
Jan 31, 2007 09:41 AM
