Spray paint project
Old Mar 6, 2017 | 06:58 PM
1999sel's Avatar
1999sel
Default Spray paint project
Hi I am new to the forum. I recently bought my 92 SC400. One of the doors has clear coat peeling, so I ordered some OEM color spray paints and repainted my door. Here is the process:
Clear coat peeling:
Taping the door - see clear coat is also peeling above the side window:
Sand the original paint with 600 grit sand paper. Note that I also bondo some minor dings in the process. Of course sand down and flatten the surface as well:
Tape the whole car and apply primer. I ordered the red base primer:
Spraying the base coats - OEM 3K3 Garnet Pearl Red:
More base coats:
Applying clear coats:
Once the clear coat is dry, I noticed quite a bit of orange peel. I expected this since the spray can can't match the finer paint particles from the traditional spray gun. As a result, I need to wet sand the painted surface to smooth it out. Started with 1000 grit, 1500 grit and 2000 grit.
Wet sanding completed:
Then polish compound was applied. Beginning to see the result:
Regular wax was then applied. Here is the final result. Not bad for a spray paint job.
For your information, I've used 2 cans of base coat, 2 cans of clear coat and 1 can of primer. Material cost about $120 (i.e. paint, sand paper, tape and wrap etc...)
Old Mar 6, 2017 | 07:05 PM
totrider's Avatar
totrider
Default Well Done. :)
Nice Job.Looks like I'll be doing that too in the near future..
Old Mar 6, 2017 | 07:22 PM
BlueJ's Avatar
BlueJ
I'm definitely gonna have to try this on my SC as well , definitely a job well done.
Old Mar 6, 2017 | 07:28 PM
1999sel's Avatar
1999sel
Thanks! The scariest part is sanding off your original paint, LOL. The most important part is the wet sanding to smooth out the surface.
Old Mar 6, 2017 | 07:29 PM
ThomasGS4's Avatar
ThomasGS4
Nice job, how does it match the surrounding panels?
Old Mar 6, 2017 | 07:34 PM
1999sel's Avatar
1999sel
You be the judge:
Old Mar 6, 2017 | 07:59 PM
ThomasGS4's Avatar
ThomasGS4
Looks great!
Old Mar 7, 2017 | 08:18 AM
myLEXsc400's Avatar
myLEXsc400
that came out fantastic!!!
Old Mar 7, 2017 | 10:45 AM
Brennen01's Avatar
Brennen01
Did you use a 2K clear?
Old Mar 7, 2017 | 11:41 AM
1999sel's Avatar
1999sel
No, I just used the regular clear coat can from automotivetouchup.com. No mixing needed.
Old Mar 7, 2017 | 01:13 PM
Brennen01's Avatar
Brennen01
Thumbs up
That's the same website I got my stuff from, I painted my fender about 1 year ago with their primer, base, and a 2K clear coat! I'm finally about to get the entire car painted professionally.
Old Mar 7, 2017 | 01:22 PM
1999sel's Avatar
1999sel
Does the color match with the rest of your car? I am glad that mine came out pretty close to the OEM color.
Old Mar 7, 2017 | 08:27 PM
2KHarrier's Avatar
2KHarrier
Very nice write up and great photos to document the process. from the pictures, it looks fantastic AAA+++
Old Mar 8, 2017 | 07:31 PM
Brennen01's Avatar
Brennen01
Yeah I was very happy with how mine came out, I'll see if can find some pictures. After seeing how yours looks after the wet sanding I wish I would have done that to mine!
Old Mar 10, 2017 | 04:06 PM
kez's Avatar
kez
Is your car for sell in central jersey my boy sent me a craigslist link
