help i need springs
Old May 24, 2003 | 07:27 AM
jaysmooth's Avatar
jaysmooth
Exclamation help i need springs
what springs are available that drop the sc more than an inch, and where can i find them. the eibachs only drop an inch and by my calculations that means there still is a 2 1/2 gap in the front. drop me a line please!!!!! I need this thing lowered bad
jay
Old May 24, 2003 | 07:59 AM
RobSoVIP's Avatar
RobSoVIP
try searching!- there are issues with dropping the SC over an inch- supra TT eibachs will give you a 1.3 inch drop in the front, and 1 in the back... I don't know how much the tien s-tech srings will drop you, if you want to go low, get coilovers
Old May 24, 2003 | 09:25 AM
jaysmooth's Avatar
jaysmooth
Default springs
why is there a problem with dropping more than an inch. is it just because of manf. specs or something else. do you have springs if so what kind. and any pics of eibach lowered sc's would be greatly appreciated so i could get a feel for the look of those.
thanks
jay
Old May 24, 2003 | 01:21 PM
ForNgoods's Avatar
ForNgoods
intrax makes a set of springs for our car that drops it 1.5 all around but i'm not sure the quality is all that great... jus get huge *** rims if u want to get rid of the gap and if the car looks hopped up then add some side skirts.
khang
Old May 25, 2003 | 01:03 PM
jaysmooth's Avatar
jaysmooth
thanks for the replies guys
jay
Old May 25, 2003 | 09:58 PM
wmulli's Avatar
wmulli
Default Re: springs
thanks
jay
Here's a pic of my front with the Supra Eibach's and 18 inch wheels. I think the Supra Eicbach's are about 0.1 inch lowere than the Eibachs for the SC. The tires are the same diameter as stock, but the wheels make them look bigger. Anyway, this is about the gap you'd have with stock tires
Old May 25, 2003 | 09:59 PM
wmulli's Avatar
wmulli
... and the rear ...
Old May 26, 2003 | 06:23 PM
jaysmooth's Avatar
jaysmooth
Default thanks
nice pics. thanks alot. what exactly do i need to do the same look. thats the look i'm hoping for. i was going to go with coilovers to get enough drop but that looks real decent
Old May 26, 2003 | 09:44 PM
wmulli's Avatar
wmulli
Thanks. Like I said, those are the Eibach springs for the Supra TT with KYB AGX shocks. If you were planning to use coilovers, I'd say go for it! You can get the same height adjustment (even more so!), plus you'd get better ride quality (using something like the Tein CS's as opposed to the Tein HA's).
It all depends on what you're after. If you want looks and a nice ride, Tein CS's, if you want to handle like you're on rails, go with the Supra TT Eibach's/AGX or the Tein HA's and put up with the stiffer ride.
Just my $0.02
Old May 28, 2003 | 10:28 AM
SCLEX's Avatar
SCLEX
How is the ride quality compared to stock? Does it bounce alot, or is it just stiff, so you can take corners faster?
-richard
Old May 28, 2003 | 01:07 PM
wmulli's Avatar
wmulli
Heh heh, it doesn't "bounce" AT ALL! Even on the softest shock settings, it's still noticably stiffer than stock, i,e,. you can't push down and bounce the corners at all. The plus is that it goes around corners like it was on rails The car just exudes confidence on twisty mountain roads
Old Jun 10, 2003 | 08:26 PM
eric150db's Avatar
eric150db
I found another option which i havent found any info on these forums. Its a tokico full suspension kit for the supra. It lowers the car 1.25 inches all the way around, and you can get the kit with 5 way adjustable illuminas or non adjustable hp's. They whole kit can be had for around 550 if you look around.
Old Jun 21, 2003 | 01:34 PM
Khaos's Avatar
Khaos
wmulli,
Did you have to do any camber adjustments on your set up with the Supra Eibach springs?
Any uneven tire wear?
That setup looks exactly like what I want on my SC300.
Thanks
Old Jun 21, 2003 | 02:19 PM
wmulli's Avatar
wmulli
I know a lot of people have had alignment/tire wear trouble with the Supra springs, but mine aligned perfectly and the tire wear is dead even.
Old Jun 21, 2003 | 05:04 PM
AzLex's Avatar
AzLex
How slammed do you want. Sprint makes springs that lower the car 1.8 all around. By the time they settle it will be close to a 2inch drop
