The Deadpool SC
Old May 24, 2016 | 02:59 PM
  #121
Maximo018's Avatar
Maximo018
This is going to be a good build
Old Jun 10, 2016 | 03:31 PM
  #122
MrCJ305's Avatar
MrCJ305
Back with a few updates. Started doing gaskets and seals as well as taking the stock twins off. Why is he taking the stock twins off now? Well I've decided to go big single while the engine is already out being that it's easier to work on so why not? Pretty much have everything as far as manifold...turbo...oil lines...and waste gate. Also changing the front sump oil pan to rear sump of course. Will be put back together tomorrow with new valve cover seals and rear sump. Had to buy Toyota Black sealant.
Attached Thumbnails The Deadpool SC-13445857_1020472704672967_83618352_o.jpg   The Deadpool SC-13410892_1020472688006302_1494414253_o.jpg   The Deadpool SC-13405274_1020472721339632_816551296_o.jpg   The Deadpool SC-13442107_1020472708006300_723048528_o.jpg   The Deadpool SC-13351181_1020472778006293_1793671153_o.jpg
The Deadpool SC-13445919_1020472771339627_2063767523_o.jpg   The Deadpool SC-13410552_1020472811339623_120522522_o.jpg   The Deadpool SC-13446304_1020472794672958_1619466541_o.jpg
Old Jun 10, 2016 | 03:45 PM
  #123
MrCJ305's Avatar
MrCJ305
Pics of the Treadstone cast iron turbo manifold
Attached Thumbnails The Deadpool SC-13405090_1020472901339614_791422467_o.jpg   The Deadpool SC-13410915_1020472908006280_1964126990_o.jpg
Old Jun 29, 2016 | 06:13 AM
  #124
MrCJ305's Avatar
MrCJ305
Rear sump conversion is complete
Attached Thumbnails The Deadpool SC-13445983_1020990977954473_1651188661_o.jpg   The Deadpool SC-13410591_1020990987954472_597721180_o.jpg   The Deadpool SC-13410810_1020990984621139_360574770_o.jpg   The Deadpool SC-13410917_1020990994621138_1106745160_o.jpg   The Deadpool SC-13446377_1020991011287803_824512873_o.jpg
Old Jun 29, 2016 | 06:31 AM
  #125
MrCJ305's Avatar
MrCJ305
My Precision 46mm waste gate & CX Racing GT35R with anti-surge and upgraded billet wheels came in. I'll be running the CX for a short period til I upgrade butit should spool very fast with the .68 rear housing
Attached Thumbnails The Deadpool SC-13570279_1031521503568087_1616759741_o.jpg   The Deadpool SC-13549030_1031521463568091_1972661400_o.jpg   The Deadpool SC-13570259_1031521466901424_1183208696_o.jpg   The Deadpool SC-13549284_1031521853568052_837317859_o.jpg
Old Jun 29, 2016 | 06:37 AM
  #126
MrCJ305's Avatar
MrCJ305
Replaced the valve cover seals and used Toyota black to assist. Swapped out the old spark plugs as well. Decided to high temp wrinkle black the valve covers and paint the coil pack cover while I was at it.
Attached Thumbnails The Deadpool SC-13575593_1031521856901385_1503191738_o.jpg   The Deadpool SC-13579733_1031521886901382_1511284327_o.jpg   The Deadpool SC-13570205_1031521943568043_485019667_o.jpg   The Deadpool SC-13555832_1031521966901374_327885052_o.jpg   The Deadpool SC-13569914_1031521983568039_1438597660_o.jpg
The Deadpool SC-13555743_1031522030234701_2120795072_o.jpg   The Deadpool SC-13569833_1031522013568036_301167487_o.jpg
Old Jun 29, 2016 | 06:45 AM
  #127
MrCJ305's Avatar
MrCJ305
Installed the wire harness back on
Attached Thumbnails The Deadpool SC-13570092_1031531123567125_1887225488_o.jpg   The Deadpool SC-13570204_1031531126900458_1899399213_o.jpg
Old Jun 29, 2016 | 08:07 AM
  #128
MrCJ305's Avatar
MrCJ305
Went ahead and high temp wrinkle painted the intake manifold as well...finished the coil pack cover and did the turbo compressor housing. Engine & trans is set to go back in
Attached Thumbnails The Deadpool SC-13524196_1031531710233733_302272364_o.jpg   The Deadpool SC-13549171_1031531550233749_1323296801_o.jpg   The Deadpool SC-13579798_1031531670233737_419212006_o.jpg   The Deadpool SC-13517806_1031531553567082_1351752266_o.jpg   The Deadpool SC-13509871_1031531753567062_1188558338_o.jpg
Old Jun 29, 2016 | 08:27 AM
  #129
CatManD3W's Avatar
CatManD3W
What paint did you use on compressor housing....i have tried all high temp paint options and none of them worked.....its gets a lot hotter than you think
Eventually had to go powdercoated...
Old Jun 29, 2016 | 03:58 PM
  #130
MrCJ305's Avatar
MrCJ305
Hey I ended up using VHT High Temp flat black...had good reviews and a ton on the muscle heads use it on exhaust. Says it's good for up to 2000°F. We'll see...like I said this turbo is a test run...but eventually I'll be going Borg Warner.
Old Jul 25, 2016 | 05:22 AM
  #131
MrCJ305's Avatar
MrCJ305
And Deadpool's heart transplant begins finally
Attached Thumbnails The Deadpool SC-13833286_1048297625223808_73613051_o.jpg   The Deadpool SC-13639707_1048297041890533_750849369_o.jpg   The Deadpool SC-13844145_1048296475223923_399530305_o.jpg   The Deadpool SC-13838055_1048296521890585_1228159198_o.jpg   The Deadpool SC-13835877_1048296888557215_226091427_o.jpg
The Deadpool SC-13833149_1048296988557205_1738092791_o.jpg   The Deadpool SC-13840404_1048296461890591_2060405880_o.jpg   The Deadpool SC-13843478_1048296661890571_595898808_o.jpg
Old Jul 25, 2016 | 11:18 PM
  #132
Maximo018's Avatar
Maximo018
Yay. And what's with the clean MKIII in the back ground? Lol
Old Jul 26, 2016 | 05:03 AM
  #133
MrCJ305's Avatar
MrCJ305
That's my boy Pedro's...he's prepping that for the street soon. Going to be a bad boy once it gets finished and out on the road.
Old Jul 28, 2016 | 10:05 AM
  #134
MrCJ305's Avatar
MrCJ305
Just a quick update...car is pretty much done but ran into a little hiccup along the process path with the drive shaft not mounting up to the trans. Hoping it's just the trans flange because I have a SC400 drive shaft. Trying to source a SC400 trans flange. Shout out to the a**hole that sold me the wrong flange.
Old Aug 5, 2016 | 10:44 AM
  #135
MrCJ305's Avatar
MrCJ305
So finally I was able to find the right flange from the SC400 trans at a local yard I also bought a new Gate's Micro-V (Part # K060775) needed for the upgraded ATI Super Damper from Real Street.
Attached Thumbnails The Deadpool SC-13901854_1055888181131419_1951214780_o.jpg   The Deadpool SC-13901951_1055888087798095_1185285436_o.jpg
