Lextreme Torque Converters
Old Oct 14, 2015 | 07:29 AM
LoveSCs's Avatar
LoveSCs
Default Lextreme Torque Converters
Anyone know if Lextreme is still modifying torque converters?
Does anyone use one and have any input as to performance and reliability?
I will be getting my trans ATF built and need an upgraded TC.
Thanks
Old Oct 14, 2015 | 02:39 PM
gerrb's Avatar
gerrb
Super Moderator
get the ATF TC so you are dealing with the same company and if they are problems , it is easier to get help if you both got the items from them. They will give you a good deal.
Old Oct 14, 2015 | 03:46 PM
LoveSCs's Avatar
LoveSCs
Thanks Gerry. I was thinking of that, but looks like Lextreme only charges $180, and they weld all of the fins on the TC. Sounds like a really good deal, compared to $1300 for the ATF converter. I will have to ask them though what they would charge for a package deal
Old Oct 14, 2015 | 06:14 PM
SEIDO's Avatar
SEIDO
I have a '97 SC300 - Auto.
What kind of HP difference will a torque converter make?
Do you guys recommend a certain brand?
Old Oct 15, 2015 | 01:49 AM
TXMAG's Avatar
TXMAG
It won't make a HP difference at all. Your selection of a torque convertor should be based on a number of factors such as what the car is used for, where in the RPM band it makes power, how much it weighs, suspension setup, etc. It's damn near a science if you want to get the maximum possible benefits out of it.
Old Oct 15, 2015 | 03:47 AM
LoveSCs's Avatar
LoveSCs
True, I just need it to be able to handle 550, maybe 600rwhp. I'm not so sure the stock TC can handle that much.. Anybody know how much the stock TC can handle??
Old Oct 15, 2015 | 08:45 AM
gerrb's Avatar
gerrb
Super Moderator
You have to know exactly what torque converter it is , are they giving you a new converter or working on yours , is it new or used , what is the stall and so on.
Torque Converters are chosen not really based on horsepower . You choose your torque converter based on the use of the car like is your car primarily a drag car or street car so you need to choose low or high stall converter , etc.
The ATF converter is a new 3500 stall converter for the ATF built tranny. But again you can choose the stall you need base on car use.
Old Oct 15, 2015 | 09:59 AM
LoveSCs's Avatar
LoveSCs
You can purchase one from them and send yours back as a core. But in my case, since not many people need an upgraded 1jz TC, I will just send him mine for rework. They do have the ability to change the stall, but to be honest, I don't really care about the stall because I do not race. I just have some fun on the street. My primary reason for sending it to them is because they weld the fins so that it can handle more power with minimal deflection. That's kind of why I am hoping that they still do the service because a $1300 TC would be overkill for me. I'm already going overkill on the trans, but that's because I don't have an option if I want to push 500+rwhp through the auto. I think ATF is the only way to go, but it would be nice if there was a reliable 600hp setup that could be had for cheaper.
Thanks
'95_sc300
Feb 28, 2008 01:43 PM
want sc300
Nov 18, 2007 03:13 PM
kris-300
IS - 1st Gen (2001-2005)
Sep 15, 2003 02:09 PM
