2jzgte block deck height
Old Sep 23, 2015 | 10:11 PM
GTX580's Avatar
GTX580
Default 2jzgte block deck height
I tried searching before but could not find any info on this. I accidently scratched my block deck using a razor blade to remove gasket material. It is near the bore, I am sending the block to the machine shop to resurface the block. Can anyone tell me what the maximum thickness that can be remove from the block? or how much total can they remove from the head+block before I have to use a thicker headgasket.
I only came across to one post saying that .010 is acceptable but not much info there.
Thanks.
Old Sep 24, 2015 | 09:05 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
Its a zero deck block, so its supposed to be junked after that technically... I haven't ever done it but I think people have done that before and can get away with it on stock cams, but maybe you should just pick up another block it will be less than the cost of dissasembly and machine work by far, and you get spare parts.
how bad is it scratched? maybe you can just smooth it down and let the headgasket seal the rest as it has a viton coating on it that can handle tiny imperfections.
if you take off .010 and nothing off the head then it should be fine but will bump up the compression sligthly above 10:0 stock, personally I would throw a 2jzgte gasket on there for little extra insurance if you do get it machined, and you should end up around a ballpark of 9.5 =compression ratio.
also depends on if a stock build or if you are planning for boost later. someone that has done it will hopefully have more info on how much you can machine safely, I just know at TDC pistons are at the block deck height.
Old Sep 25, 2015 | 03:34 PM
GTX580's Avatar
GTX580
Ali, Think this is ok?
Forge pistons and rods going in the build but nothing intense, maybe mid 600s.
Old Sep 25, 2015 | 04:17 PM
gerrb's Avatar
gerrb
Super Moderator
looks to me it is inside the fire ring , looks ok to me. It is far from any coolant port where coolant can get into the cylinder . I don't think any decking is needed.
Old Sep 25, 2015 | 06:38 PM
zneubauer's Avatar
zneubauer
I'll give a second go on that. ^ I had a block with a few scratches and it turned out decent. I don't remember where, but I do remember them being mentioned. Anyways, looks good to me!
Old Sep 25, 2015 | 07:13 PM
GTX580's Avatar
GTX580
Thanks for the info!
Old Sep 28, 2015 | 03:42 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
I agree with the others no reason to take it apart you can see its inside of where the old gasket sealed, just clean it up and slap a new gasket on it.
Sandlex2j
Sep 2, 2014 01:21 PM
Answer300
SC400 / 300 Classifieds
Aug 7, 2013 04:40 PM
blklexsc3
Feb 15, 2008 11:51 AM
rd122481
Nov 11, 2007 05:21 PM
