Electrical issue help!!!
Old Sep 20, 2015 | 11:35 AM
yauny's Avatar
yauny
Yes swapped ecu out and same caps leaked again
Old Sep 20, 2015 | 11:44 AM
kolessc400's Avatar
kolessc400
Was it used or new... And did the symptoms change a little
Old Sep 20, 2015 | 01:15 PM
yauny's Avatar
yauny
It was a refurbished one and it did for a day then back to the same ****
Old Sep 20, 2015 | 01:16 PM
yauny's Avatar
yauny
Where are the grounding locations?
Old Sep 20, 2015 | 02:54 PM
kolessc400's Avatar
kolessc400
These are some of the diagrams i have
Attached Thumbnails Electrical issue help!!!-1442785529365.jpg   Electrical issue help!!!-1442785560657.jpg   Electrical issue help!!!-1442785583523.jpg   Electrical issue help!!!-1442785609158.jpg   Electrical issue help!!!-1442785625163.jpg
Old Sep 20, 2015 | 02:58 PM
kolessc400's Avatar
kolessc400
Here's more of it the last pic has on this one states the ground points
Attached Thumbnails Electrical issue help!!!-1442786101106.jpg   Electrical issue help!!!-1442786117954.jpg   Electrical issue help!!!-1442786167762.jpg   Electrical issue help!!!-1442786194607.jpg   Electrical issue help!!!-1442786216779.jpg
Old Sep 20, 2015 | 03:01 PM
kolessc400's Avatar
kolessc400
This it's the engine control for a 96 sc400
Attached Thumbnails Electrical issue help!!!-1442786367996.jpg   Electrical issue help!!!-1442786385556.jpg
Old Sep 20, 2015 | 03:05 PM
yauny's Avatar
yauny
I just dont kno which wire are the signal wires and what the other wire is for when it comes to the cam and crank sensor due to the cam sensors are ground to the engine.
kolessc400's Avatar
kolessc400
I hope this helps
Old Sep 20, 2015 | 03:13 PM
kolessc400's Avatar
kolessc400
Signal goes from ecu cam2 green left cam pin 25...cam1 right cam brown pin 26... crank yellow pin 27... And ground goes back to ecu amd murge into pin 7 red and pin 5 red... So
Old Sep 20, 2015 | 03:14 PM
kolessc400's Avatar
kolessc400
On page 81 of diagram will show you the cam and crank sensors
Old Sep 20, 2015 | 06:28 PM
yauny's Avatar
yauny
So the cam sensors have 2 grounds and a signal wire?
Old Sep 20, 2015 | 06:47 PM
kolessc400's Avatar
kolessc400
Technicly it has 2 cams each with there own signal wires and both cams go into 1 ground with the crank sensor then it splits the 1 ground it made to 3 diffrent grounds to the ecu
sc300NJ
Feb 5, 2016 06:13 AM
yauny
Sep 19, 2015 08:36 AM
yauny
May 23, 2015 08:28 PM
HeMan26
Apr 30, 2015 08:07 PM
freegard
Aug 14, 2014 06:34 PM
