vacuum line spaghetti
Old Sep 3, 2015 | 08:08 PM
scblackout's Avatar
scblackout
Default vacuum line spaghetti
I noticed 2 unplugged vacuum lines on my 300 so I connected them together. After seeing a couple of other pics on the forums here, it looks like the first pic, single line that I am pointing to should actually be going back underneath the intake manifold somewhere.
Does anyone definitively know where these lines are supposed to go?
*the sticker on my hood only shows the 3 lines together, it does not show the 4th single line.
Here is where I connected the other end as it was missing, obviously wrong, but I don't know what this piece is and where the 2nd line goes.
Thanks for the help
Old Sep 4, 2015 | 08:26 PM
Bflatsharp's Avatar
Bflatsharp
The hose on the throttle body goes to the throttle opener right behind the tps.
Old Sep 4, 2015 | 10:19 PM
t2d2's Avatar
t2d2
I don't know the SC300 layout, but to add to what Blfatsharp said, that sure looks like you've got it routed to the Heater Control Valve.
Old Sep 5, 2015 | 10:05 AM
scblackout's Avatar
scblackout
Thanks for the answer! By any chance would you have time to take a few pics?
All the hoses around the tps are already plugged into something, so I must have a few flipped hoses somehow.
Old Sep 5, 2015 | 05:51 PM
scblackout's Avatar
scblackout
Well figured out the problem.
Pic of what it should be plugged into:
The way mine is, notice a huge missing piece?
My best guess is that the prior owner took it off during maintenance and didn't put it back either to it being bad or some other stupid reason.
Not sure what a "throttle opener" is but now I need to go to the dealer and pick one up. Curious what it does as my car has been missing it the entire time I've owned it. The last 3 days the car has been running great, so go figure.
Old Sep 5, 2015 | 11:48 PM
t2d2's Avatar
t2d2
No idea what "throttle opener" refers to, but that looks like an EGR valve in your first pic. The P.O. probably deleted it. That would explain why the car ran fine all this time... Check some schematics to see if that's where the EGR is located on your car. It's on the other side on the SC400, so I'm unsure.
Werunbklyn
IS F (2008-2014)
Apr 26, 2020 11:32 AM
esc300
Mar 11, 2014 02:54 PM
Chronolick
Mar 1, 2013 02:12 PM
ScWift92
Jan 15, 2013 04:07 PM
bighitbike
Performance
Jun 6, 2007 08:13 PM
