1JZGTE Engine
Old Apr 4, 2003 | 07:51 AM
quikturbo's Avatar
quikturbo
Thanks for the information. I'm just curious how hard it would be to locate a soarer driveshaft as well as the rear end. Anyone have any sources?
As for the swap, I swapped in the 2jz myself. I picked up a complete US spec 98 motor with 30k on it for $3k, it was missing some electronics i.e. ignitor, resistor, noise surpressor, etc.. also was missing the motor mounts so I went with some trd mounts, that is only scratching the list, all of the little things ADD UP!!! If you ever have any question just shoot me a pm.
Chris
Old Apr 4, 2003 | 11:25 AM
Bean's Avatar
Bean
CL Folding 1,000,000
i think the clutch idea is; you have to use a MKIV flywheel and pressure plate; but a MKIII disc... the MKIII clutches won't bolt up to a MKIV bolt pattern...
speaking of transmissions, i saw a T56 transmission adapter for the 2jz now THAT would be interesting if it could be done because they are a dime a dozen and prolly just as strong as the supraTT 6-speed
Old Apr 4, 2003 | 12:15 PM
VSsc400's Avatar
VSsc400
if you are looking for this swap look up this Item # 2409460550 on the poplar auction site.
its with automatc tranny but it seems cheap.
Old Apr 7, 2003 | 10:22 AM
Idrockasupra's Avatar
Idrockasupra
what is poplar ?
Old Apr 11, 2003 | 06:01 AM
Idrockasupra
BTW does anyone know if a DP made for the soarer will work with on a US Spec SC300 with a 1JZ ? Thanks.
98Sc3001jz
Mar 24, 2014 04:44 PM
sj408
Apr 15, 2009 02:06 PM
jami808
Feb 4, 2007 08:13 PM
soarerxx
Sep 14, 2004 06:51 AM
Dimcorner
Jan 20, 2003 05:08 AM
