cluster needles
Old Mar 28, 2003 | 01:01 PM
heavy wate's Avatar
heavy wate
Default cluster needles
i just replaced my cluster and found out that it was a cluster from the 95 and up, since it had the amber bulbs. after reading up on the cluster searches i found out that the rpm and the speedo wouldnt work properly on my 92. is there a way i can take the needles out of the 95 cluster and put them on the 92 cluster ? or should i leave it the way it is ? thanks for all you help.
Old Mar 28, 2003 | 01:21 PM
jimmit's Avatar
jimmit
Well the speedo problem alone would make me consider fixing or replacing the cluster. Where did you get it from? Is there anyway to exchange it for a 92 cluster or was it from ebay, the classifieds from CL or any place you can get it changed? I'd find a way to fix it if I can get a different cluster. Is your speedo dead or not giving the right speed? Either way if I was in your posititon I would try to get it fixed as soon as possible. Too many speeding tickets already.
Old Mar 29, 2003 | 12:42 AM
heavy wate's Avatar
heavy wate
i got the cluster from my friend. at first i didnt know they made different clusters, i only found out when i did a search for "removing cluster" that different clusters were made from different cars, and i knew that the cluster i had was a newer one since it had back amber lights. i didnt drive the car after i installed the cluster, but when i started the car, the rpm idle was around 1200-1300 which i dont think its the right idle. as for the speed im going to see if it deviates a lot from norm, if it does i might just change the needles. thanks for you help jimmit
Old Apr 2, 2003 | 11:24 PM
olegmalkin's Avatar
olegmalkin
Hey, when you replaced the cluster did it carry over your actual mileage or does it show a different mileage.
Old Apr 3, 2003 | 06:44 AM
heavy wate's Avatar
heavy wate
yes the cluster now shows a different milage, but the gas and temp needle dont seem to be measuring properly.
TRDmike
SC400 / 300 Classifieds
Jun 30, 2012 09:36 AM
md531e
Dec 12, 2010 01:42 PM
g3t0ut
Oct 21, 2009 01:24 PM
Dble Agent
Dec 27, 2003 01:11 PM
