SC- 1st Gen (1992-2000)
View Poll Results: Do you remove/install your oil filter from the top or bottom on your SC300?
Top
20
68.97%
Bottom
31.03%
Voters: 29. You may not vote on this poll
SC300 owners: Do you change your oil filter from top or bottom of engine? (Poll)
Old 06-01-15, 07:07 PM
Luxor
Luxor's Avatar
Question SC300 owners: Do you change your oil filter from top or bottom of engine? (Poll)
Hello guys, I am just curious how many of you SC300 owners remove your oil filters from the top of the engine and how many of you remove the oil filters from the bottom?
I personally change my filter from the top of the engine because I think it's easier that way since the oil filter is located on the upper part of the engine. If you change your filter from the bottom, please state why you do it this way? I am just curious...
Old 06-01-15, 11:15 PM
eknine9
eknine9's Avatar
No reason to go from below. Can get a nice grip on it with my palm from above and just twist it out, I bought a fancy strap wrench for oil changes 4 or 5 years ago, but It never quite grips right. I'd rather let the car cool down like 20 minutes and just twist it out by hand.
Old 06-02-15, 09:55 AM
jimbosr1
jimbosr1's Avatar
i have always changed side mount filters when the engine is cold.when cold the filter doesnt leak a drop of oil.been doing this for 40 years,my 86 mr2 is the same way.
i agree ,no need to remove it from the bottom.
Old 06-02-15, 10:15 AM
Ali SC3
Ali SC3's Avatar
was from the top before the front facing intake manifold, now I can loosen it from the top, but it has to be removed from the bottom cause it wont physically come past the intake anymore. not ideal but it works.
Old 06-02-15, 12:30 PM
N1T3MARE
N1T3MARE's Avatar
Top. Much easier
Old 06-02-15, 12:32 PM
SCereal
SCereal's Avatar
Bottom due to FFIM (Can't even see much less touch filter with mine) and PHR relocate kit makes it EASY.
Old 06-02-15, 04:03 PM
jennie
jennie's Avatar
I'm a top. heh...heh.
Old 06-02-15, 07:43 PM
Luxor
Luxor's Avatar
Thanks for all the feedback, I didn't know that FFIM made it harder to reach for the oil filter from the top.
Old 06-03-15, 10:22 AM
czar07
czar07's Avatar
Its almost impossible to get it from the top if you have a FFIM / GTE engine. I have given up trying to use my hands from the bottom, now I just put a filter removal tool on a long extension rachet and use that
Old 07-06-15, 12:25 AM
Matromony
Matromony's Avatar
I change from top and always seem to make a fat mess
Old 07-06-15, 01:39 PM
InLyneTrbo
InLyneTrbo's Avatar
Bottom, but I have a GTE swap
HadYurPhil
RX - 1st Gen (1999-2003)
16
08-06-18 05:24 AM
johnnieliu
06-16-13 12:37 PM
durtysc300
Performance & Maintenance
07-07-09 07:03 PM
SC300 J
07-11-07 12:56 PM
LC1338
12
05-24-06 11:23 PM
Quick Reply: SC300 owners: Do you change your oil filter from top or bottom of engine? (Poll)
