1995 SC300 torque specs
Old Apr 7, 2015 | 03:27 PM
SoarerXavi's Avatar
SoarerXavi
Default 1995 SC300 torque specs
Looking to change my brake pads today, how much should I torque when done putting back brake pads?
Old Apr 7, 2015 | 03:38 PM
SoarerXavi's Avatar
SoarerXavi
Anyone please......
Old Apr 7, 2015 | 03:47 PM
ems's Avatar
ems
from autozone
To install:
Temporarily install the caliper on the torque plate with the 2 installation bolts.
Hold the sliding pin and tighten the mounting bolts to (except SC 430) 25 ft. lbs. (34 Nm), Sc 430 tighten to 77 ft. lbs. (104 Nm).
Connect the brake line with 2 new gaskets and tighten the union to 29 ft. lbs. (39 Nm).
Refill the reservoir as necessary and bleed the brake system.
Before servicing the vehicle, refer to the Precautions section.
Remove the rear wheel.
Remove the union bolt and gasket from the caliper, then disconnect the flexible hose from the caliper. Use a container to catch the brake fluid as it drains out.
Remove the 2 installation bolts.
Remove the caliper from the torque plate.
To install:
Install the caliper onto the torque plate.
Install the 2 installation bolts and tighten to 77 ft. lbs. (104 Nm).
Install the flexible hose lock securely in the lock hole in the caliper. Connect the brake line with a new gasket and tighten the union bolt to 22 ft. lbs. (30 Nm)
After installation, fill brake reservoir with brake fluid, bleed brake system.
Check system for leaks.
Install the rear wheel.
Old Apr 7, 2015 | 03:52 PM
eknine9's Avatar
eknine9
I didn't bother with torque specs when I did mine, just tighten it to the point where it becomes difficult. Don't over-tighten them.
hqduong
RC F (2015-present)
Sep 17, 2018 04:26 AM
fortitude
Jan 4, 2016 06:54 PM
mulva68
Feb 3, 2015 02:17 PM
mikeaycock
Jun 8, 2006 05:17 PM
dbullen
Apr 2, 2006 09:24 PM
