Oill Leak Need Help
Old Mar 24, 2015 | 11:15 AM
Durvelle27's Avatar
Durvelle27
Exclamation Oill Leak Need Help
Ok so i have 1992 SC400 and it has a oil that gets pretty apparent. I had the Valve cover gaskets replaced hoping that was the issue but it's still leaking. When the car is running it looks like it's coming from the upper oil pan but i'm not sure. Has anyone had a similar problem like this. If so what was the problem ?
Old Mar 24, 2015 | 12:44 PM
eknine9's Avatar
eknine9
That's a pretty bad oil leak.
After you did the valve cover gaskets did you clean up the top of the engine real nice? If so is there new oil up there, or is it only dripping through at the bottom now?
When you did the valve cover gaskets, how did your spark plugs look? Were they fouled with oil or were they relatively clean?
Old Mar 24, 2015 | 02:34 PM
Durvelle27's Avatar
Durvelle27
yes and i don't see any oil on top of the engine. Didn't check spark plugs. It's only dripping from the bottom now.
Old Mar 24, 2015 | 06:30 PM
Reaper617's Avatar
Reaper617
It could be cam seals or the front crank seal.
Old Mar 25, 2015 | 11:37 PM
eknine9's Avatar
eknine9
If the top is dry now, just based on how the car is parked and where the leak is I'd be willing to bet it's what reaper said, front crank seal has probably gone bad.
Old Mar 26, 2015 | 09:07 AM
Durvelle27's Avatar
Durvelle27
Ok so i took it to a mechanic and he said its the rear main seal. Is it hard to replace ?
dildil
GX - 1st Gen (2003-2009)
16
Aug 28, 2019 09:34 PM
Ohoopee
IS - 1st Gen (2001-2005)
Sep 10, 2017 05:40 AM
Agent$mith
May 25, 2015 11:29 AM
bmwboyee
RX - 1st Gen (1999-2003)
Jun 25, 2011 07:46 AM
mildawg
Jan 20, 2010 07:00 AM
